Bandsaw dust collection
Doug Ridley
To all who answered my questions, I got it all done and it works perfectly. Almost no dust on the tabletop. This has been a pain ever since I got the collector . Thanks for all the suggestions.
Doug Ridley
Deluxe setup, Doug!
I can see why not a speck escapes. That is some serious collecting apparatus. Nice job.
Looks great!, How about a little experiment?
I'm one of the posters that suggested the part under the table. I had a version that requires the hole in the door and changed to the under the table type. You have both.
How about doing a little experiment? Try it all three ways. Pick out a scrap and make a bunch of Identical cuts. One set with it just as you have it. One set with one one port and then another set with only the other port, and see how much dust ends up on the table. Shouldn't be too much trouble to momentarily seal one port or disconnect one of them.
I did away with the through the door port because it interfere with changing the blade. Yours looks better in that regard. I'm trying to decide whether to put it back or go with an over the blade set up.
And, tell us if over time dust builds up in the lower wheel enclosure. I get a small amount in mine.
Eliminate tube under saw???
Tom Dunlap
Why not connect the outboard fitting into the plenum under the blade?
This would eliminate a long piece of flex tubing. The U-connector could be made from PVC/metal with a hose clamp connector just like you have for the flex tubing.
Since this was all discussed in a previous thread I'm guessing that there is a reason for the loop of flex tubing.
Tom
Re: Looks great!, How about a little experiment?
Doug Ridley
Barry, I don't think any sawdust will accumulate in the lower door as I have a tremendous amount of suction on the lower door. I'll let you know though if it does. Haven't used it an awful lot yet. It doesn't interfere at all with changing blades.
Doug, I did all of my DC system using the "by guess and By golly" system of engineering. I stared at stuff until I thought I had an answer. It might have been better if I had had some sort of flow meter.
For example, you used a pvc Tee for your fitting. It might have been better to use a Wye or a swept tee. It would be interesting to know how much the right angle bend of the Tee restricts the pickup under the blade. Wonder what percentage of air goes through each side of your connection? Wonder if both sides are really necessary? I only have the side that is under the blade and it is good, but there is still some dust that comes back to the top with the blade.
the hose I had connected tot he door was too rigid and it would slam the door shut while I was trying to change the blade. Hateful.
I am considering adding an over the blade pickup on the BS and The TS. I really don't want one on the TS because it would hang from the ceiling and I don't want anything else in my way in my tiny shop. But,. I have a general purpose hose that I move to my planer, drum sander, lathe, and router table, so moving it to the BS and TS would not be too bad. If I find the Over Blade thing to be very good, I could add a permanent pickup.
Re: Bandsaw dust collection
FredD
Good job Doug , since it slurps up the dust to your satisfaction , quibbling over the specs is just that.
I would say like Tom however , if you get a little spare time , you would improve the bottom port suction even more if you shorten the hose run.
But on the other hand a perfect result the first time is hard to improve on ;-)
FredD
Doug Ridley
While were on the subject of dust collection I also fixed up my drill press. I sort of copied this from Mike Delfuoco's shop shot no. 628 but changed it a little as I didn't need the storage space he had built into his. Again it works really good and gets nearly all of the chips as they come off the drill bit. Now I haven't used it a lot yet but it has great suction and seems to work really well.
Gotta be the worst drill bit I ever saw
Re: Gotta be the worst drill bit I ever saw
Doug Ridley
I must admit it is a little on the dull side.
