Glue questions/advice
Charlie Anderson
I usually hang out on the Turning Board, but have a general problem so thought I'd post it here.
In the picture is a plaque installed on our community stairs to the beach on the Chesapeake Bay.
At the moment the plaque is in 6 pieces due to vandals and I'm trying to make a repair instead of buying a new one. (We did replace it once.)
The plaque has about a 1/16" gap between the plastic and the frame.
I plan to use CA glue to reconnect the plaque pieces. Then I was thinking about using two faced tape on the back of the plaque with epoxy around the edges.
I don't know how to do it and still do a neat job.
Maybe I should epoxy the entire thing. That would allow me to slide the plaque around and get it centered properly.
This picture was taken before we further secured it with 6 screws.
I'm sure it will just be vandalized again as we have a running battle with the young teens in the neighborhood. But we're going to put it up again and not let them win easily.
Thanks for the help.
Re: Glue questions/advice
Don't use CA.
It has no real structural properties. I would consider using water resistant Titebond II or a thinner two part epoxy glue.
Concur
And, if you've got a router, rout some dadoes across the back side, in the areas where the splits are. 1/4" deep would be enough by whatever straight router bit you've got in the 1/4" - 1/2" range. Make some strips of some weather-resistant wood in those dimensions, and glue them in to reinforce the glue joints.
Andy Wright - Allen, TX
Have you considered gluing the pieces of the plaque to a substrate (maybe thin sheet metal?) before you put it back into the frame?
Another thought is reassemble the plaque using clear packing tape on the backside and then add a piece of clear plexiglass over top of the entire frame to provide structural support
Jesse Cloud
Here's another approach...
Find someone with a laser system (look for folk who make sports plaques) and have them run off a dozen or so copies all on wood. Once the image is in the system, copies are pretty cheap. That way you can keep up with the vandals and the weather...
Maybe I Wasn't Clear
Charlie Anderson
Only the plastic insert is broken and I was planning using the CA glue to connect the puzzle pieces.
After it's back to more or less (less because one corner is missing) back together, I'm looking for the best way to attach the plastic insert to the wood frame. The frame is undamaged.and the exposed parts have been covered with several coats of spar varnish.
I'd hope to make it so a pocket knife isn't easily slipped under the edge of the plastic.
I think a cover of Plexiglas would be completely scratched in no time.
Re: Epoxy not a good idea.....
Howard Acheson
.... as epoxy rapidly deteriorates when exposed to the UV in sunlight. Epoxy must be over coated with a number of coats of a UV resistant finish. The finish will need at least annual rehabilitation as UV inhibitors are used up as they do their work.
Re: Maybe I Wasn't Clear
How about routing out the "hole" for the insert a bit deeper. Cut out a 1/4" plywood insert and mount your plastic to the insert with an epoxy. It would be shielded from the sun as it would behind the opaque plastic. (You can also get a UV resistant epoxy.)
You can then secure the plywood to the wooden frame with whatever method pleases you. Screws, glue or whatever.
Contact a plastics retailer
Look up "plastics" in your Yaller Pages, and call around until you find a friendly one. Locally, there's a chainette - about 15 stores around California - where people will spend the entire profit on what you buy giving you good advice.
There are scratch-resistant plastics, and UV-resistant plastics; there may even be a plastic that's both those things. For the size you'll need, it could be made from unobtainium and still not cost much.
Would tempered glass work? This would be pretty hard to break, and might not be too expensive. It can be broken by an idiot with determination and a sharp pointed implement, so you would need some way to replace it fairly easily.
Have you considered getting the plaque re-made in brass or bronze, and then figuring out a theft-proof (or at least theft-resistant) attachment? Likely to get costly if you get it made retail. Some university art departments do metal casting; you might call around, if you've got colleges in the area, and see if you could sweet talk them into making you a replacement plaque as a public service.
Sort of reminds me of college days..
Our fraternity had a sign out front of the frat house. The other frats decided that they were going to break our sign.
Our faculty adviser paid for a rather large (3' x 3' x 1/2") piece of flat steel. I lugged it back to campus. I etched our fraternity "crest" on the steel and painted the steel in the summer. I dadoed out the sides, top and bottom of the supports and we carefully slid it in. One night, when the other frats were getting rowdy, they decided to try and break our sign (I believe with a baseball bat). We heard a loud melodic "clang". That was the last time they tried to break our sign.
We had to touch it up as time passed, but it never broke.
Re: Sort of reminds me of college days..
Neal in San Jose
Back in the day, kids used to drive down our rural Indiana road and smash mail boxes with baseball bats. About the third time this happened, dad had a mailbox made by a welder friend of his. It looked just like a regular mail box, but it was made out of 1/4 inch steel plate. He had it welded onto the top of a steel post, which was set in concrete. We had to use a hoist to set it in the concrete.
Once in a while we'd hear a "clang" in the middle of the night, and the next morning we'd usually find part of a baseball bat along side the mail box. I did have to repaint it a time or two, but it was never damaged. It may still be there! I always wondered what it felt like to hit something that solid with a bat while riding in a car at 30 or 40 miles per hour. I'll bet we didn't have any repeat "customers".
chuckbeck
I could go for a string of stories like those. Satisfying 'clangs'
