Unstable Internet connection questions?? OT
I have Comcast High Speed Cable Internet. I have whatever gear they provided including a Netgear router to make it possible for my son to use his laptop elsewhere in the house. The service keeps dropping off line and I have to reset the modem and router, sometimes several times a day. Had to reset it four times to send four e-mails earlier today.
Called Comcast and they had me reset the router and modem again and declared it all looked good from their end. They also had me empty my browser history. They said the fact that I seldom empty my history was part of the problem.
My questions are, is it normal for the service to drop off frequently and does emptying the browser history have anything to do with it?
Re: Unstable Internet connection questions?? OT
Bill Howatt
Problems can be caused by cached files but that is usually because one is bad or because it is there and something is wrong so the system won't download a more up-to-date one. It generally is recommended to clean them out from time to time because the number of files can get to be very large and start to slow things down. Whether or not this has anything to do with your issue remains to be seen.
Did the Comcast person go through the setup parameters on your router with you. Some of them have a Keep Alive parameter but if that wasn't set right you shouldn't have to reset your configuration.
I'm not on Comcast.
Bill
In A Word
NO not usually
Anyone who tries to tell you that your browser history is wiping your cable's connection to their transmitters is a poor liar. Your cable will drop out because
a) a power failure on your end
b) a power failure on their end
c) their hardware is malfunctioning
That said, you can have problems in your machine (computer or router) that will interfere with just that computer's access to the modem, but you're describing a disconnection such that neither computer is getting a signal from the modem. If you have cable tv, whether the TV goes out at the same time can be a give away to cable problems. Check with your neighbors to see if they're having the same issues; there's strength in numbers. I've had failures and intermittent service because of a cable splice that went bad at the connection to the street for water infusion after a storm. I bitched. The guy came out (with usual threat of charges if it's my fault). He fixed the connection. All's well.
You're not alone
For fun, google "I hate Comcast". There are entire websites devoted to dissatisfaction with this particular company.
It sure doesn't sound like your fault.
John McGaw
In my admittedly limited experience with Comcast, this sounds like business as usual. This sort of problem seems to be common where the signal from the street is weak. This can be because someone added splitters and additional wiring to the drop or because cables and connectors are damaged or because the original installer used a tap with too much attenuation. I've also seen it occur when an exterior cable got overly hot from sun exposure or when heavy rain caused water go get into a connector. Talking to their customer service is good for nothing except raising one's blood pressure.
Then only way I've ever been able to fix it for a friend (I wouldn't have Comcast anything) has been to demand that they dispatch a technician for a service call and then to follow the tech around spying on signal strength readings and such and noting everything he/she does. It is amazing how much better they can perform if someone with a bit of experience is watching every move they make.
Timely Question!
Charlie Anderson
I just this morning had the comcast techs out because I've been having intermittent outages on my internet. No problem with my tv.
When I called last week for the problem, the phone tech said he could see that I was losing service and noticed that one of my reading was higher than comcast's tolerances.
Of course, I haven't noticed an outage since I made the call. The tech today said everything was within tolerances but they had been having some problems system wide (Southern Maryland, I guess). He said the problems had been resolved.
Maybe the next time you have a problem, you can ask about this.
David Yoho
Barry, I'm in your general area and have Comcast. We have one computer out of six that is wireless and it loses connection too. While it's not as often as you say, it's still a pain to run all the way upstairs to reset the router and modem each time. I'm fairly sure to problem is with Comcast and not our equipment or browser history.
Stuart Johnson
This won't help with the outages but check to see if you can't send a reboot from your computer. I'm on ATT - DSL and from time to time the connection will drop. I can either manually reboot or just send a command from the computer. The connection between the computer and the modem stays active.
Jason Roehl in Lafayette, IN
I have Comcast.
I originally had a really cheap Linksys wireless router that I was forever having to reset (now I have to do that at our church...that's where it ended up). I bought a somewhat better Netgear router. I pretty much never have to reset it now, and between my laptop and iPhone, its wireless portion gets a pretty good workout. I still have the original cable modem (modem only, no router) that I got when I first got Insight (later bought by Comcast) cable internet. I almost never have cable or internet outages, though I am a little annoyed at the new little DTA (digital transport adapter) boxes I have to hook to my two old TVs that didn't have any sort of cable box previously (they're transitioning to an all-digital signal). One more remote each, and one more thing to plug in each. At least they're free (for now...) and supposedly I'll get another 10-20 channels with them (probably more crap I won't watch).
Jason
Jim Rahbe, Bedford Texas
They fix�d mine, I no longer have this proble
Barry,
I also have Comcast and about three years ago had a similar problem. I have one cable coming into the house for TV and High-speed Internet connection. The cable goes to a splitter which sends the signals to several the TVs and my single Internet connection via a standard TV-style coax cable.
My problem was the output of the coax going to the Comcast modem, was lower than it needed to be. Apparently the output amplitude was enough to allow the modem to work most of the time, but when the network was busy, the amplitude would decrease and I�d lose connection. Sometimes rebooting the modem would help, and sometimes it would not.
Comcast sent me two replacement routers which did not help. I asked and they sent a tech out to my house who apparently knew what he was doing. He �measured� the amplitude of the incoming signal and the signal to the Modem. He then installed a power amplifier in the attic (A real one, not a Radio Shack special). That was three years ago and I can�t remember the last time I had a TV or Internet problem.
I suggest you ask them to come out and make sure the tech measures the signal level to your modem.
Regards,
Jim R.
