Dovetail bit
Dovetail bit
Dovetail bit
Terry Alexander
I have the Rockler dovetail jig. I like it. Inexpensive and suitable for my use (kitchen and vanity cabinet drawers....not "real" furniture).
My bit is getting a bit dull.
I looked at the "specs" as to what bit was shipped and I am having trouble finding an exact match.
Q: Can I use a different bit? Change the angle possibly? Or should I keep searching until I find the "exact" bit that matches what came with the system.
As always...thanks in advance.
Terry Alexander in West Texas
Re: Dovetail bit
Re: Dovetail bit
Jesse Cloud
No experience here with the Rockler jig, but....
What spec are you having trouble matching? The one that probably matters most is depth of cut. The jig takes up some vertical space in addition to the router sole, etc, so lots of jigs require extra long bits.
Have you tried Rockler tech support? I was surprised how good they were when I called.
The other path would be just try it. As long as the bit doesn't touch the templates, it won't harm anything but your workpiece...
Let us know what you find out!
Re: Dovetail bit
Re: Dovetail bit
Unless I miss my guess, you want a standard 1/2" x 14� dovetail bit. Those are standard for most simple half-blind dovetail jigs.
Re: Dovetail bit
Just because I don't know....
Terry Alexander
...does the 1/2" refer to the shank diameter?
Reason I ask is because the Rockler jig came with a 1/4" shank bit. I don't see how I could fit a 1/2" shank bit with a collar into the jig.
Sorry......I'm pretty good at working with wood (and routers)....but.....like the subject line says.....I just don't know when it comes to "talking" technical.
TIA
Re: Dovetail bit
Not the Shank Size
David Yoho
The 1/2" refers to the width of the cut - not the shank size.
Re: Dovetail bit
Re: Not the Shank Size
del schisler
get the right degree or it will not work dovetales and pin's will not be tite I have gifkin's dovetailer and only the bits mfd. by them will work
