Bandsaw dust collection
Doug Ridley
I am looking for suggestions for ways to collect dust from an old 14 inch open stand Rockwell Delta bandsaw. I have a 4 inch drop by it but need suggestions on how to hook it up. What I have is not working real well. Ideas please.
Doug
Re: Bandsaw dust collection
Jesse Cloud
Good luck on that one! Bandsaw dust collection is a bear. I've tried lots of different things, but the best so far was a scheme Michael Fortune showed, I think in Fine Woodworking, where he put a "Y" on his DC pipe, then ran one line down by the lower guides and the another into the bottom of the saw. He rigged holders and cut a hole in the door of the saw for the bottom collection.
Bill Howatt
I have a similar collector to Jim's but nowhere near as well-fitted or nice. It works fairly well but I still get over time a build-up in the lower wheel housing.
Bill
I made a simlar hookup out of an "End Boot" from 4" duct work. Works pretty well and allows you to tilt the table.
mdclor
I would suggest putting the hole in the side opposite the door. This makes it much easier when changing the blade and the tubing isn't in the way when feeding stock. I just wish I had thought this through before I cut the hole in my door. :(
Doug Ridley
Thanks, all. I have a pretty good setup from the bottom. I'm looking for a way to get the huge mess that winds up on the bandsaw table and out in the shop. Hoping someone has an idea on that'
FredD
I riveted a five inch port in the center of the bottom door and hooked to the Oneida DC and closed up all of the holes in the cabinet that the Delta 14 inch saw came with and it does a much better job then I figured it would. The connection to the metal ducting from the DC is wire reinforced flex ducting which makes changing the blade easy.
FredD
Re: Band Saw dust collection
Doug, my band saw also delivers some sawdust back to the top of the workpiece/table. It seems this would have to be particles that failed to fall out of the teeth and were carried all the way around. I have the same problem with my TS.
I have speculated on several approaches. One obvious one would be to use and over the blade pickup. There are a number of them available for a TS, but my shop is so small I would hate to introduce another pipe or hose hanging down over the TS. I do think it would be effective, but in the way.
On the band saw, I have thought about a pickup behind the blade that would be attached to the bearing support and raise and lower with it. If the trash on the table bothered me enough, I would try that.
Another thought I had was to try to use compressed air to blow across the blades and knock the dust out of the gullets toward the dust port. This would allow the dust port to grab it and not circulate it back tot eh top of the table. obviously this would require and compressed air source and various controls to turn it on and off. Just thinking outside the box.
On a band saw, you might be able to set up a brush that would do he same thing.
Another thought is to go to Bill Pentz' site and see what he has to say about dust collection on the BS.
Part of the problem is what I call the "swipt" factor. There is a certain amount of mechanical force that is carrying these particles and when the fly off the blade they have velocity and momentum. The suction has to overcome that and grab the particles. So a shop vac mount beside the blade might co a better job of snorting the practical off the blade than the slower softer air movement from a DC. OTOH, if the pickup mounted above and behind the band saw blade were powerful enough it might suck up small work pieces and scraps. I have lost sandpaper and small parts to mine.
A couple of other thoughts. The stuff that is really important to pick up is the really fine dust, 10 microns and down. The big stuff that is laying around is messy and unpleasant, but not much of a health risk. Its the really fine stuff floating in the air that gets inhaled and is a health risk. So, and over the blade pickup might be beneficial even if it still doesn't get the course stuff. It might grab a large percentage of the fine stuff.
I have a friend that has years of experience in industry using air to handle material and to do dust collection. When I was obsessing over adding a pickup to my contractor's saw and got to about 98% below the table he advised that I quit fiddling. His point was I could completely redo it over and over and might only get worse. At some point you have reach the practical limit and its time to do woodworking and then clean up a little. Its a workshop and there is going to be some mess and clean up.
Doug Ridley
Thanks Barry. I like your idea of over the blade collection. I have been down there this morning trying to figure out if I could somehow mount suction to the bar that increases the cut height. I might be able to mount a shop vac there and plug in to a gizmo that starts the vac when the saw starts. I just thought somone on here might have already done something I could look at.
Normp
I installed the bottom dust port on my 14 in. bandsaw and haven't looked back since. It now picks up all the dust that was being thrown around the lower wheel and exiting from the back top of the lower cover area. Sometimes I forget to turn the dust collector on and I immediately see the difference in dust being blown around. Both dust ports effectively remove most of the dust generated.
Norman
Doug Ridley
Now THAT looks good. I think I'm gonna try to do much the same thing. Thanks.
del schisler
Normp I have the side 4" port Where did you get the port that is under the rollors ? Did you make it Look's like a 2" down to the 4" thanks
Normp
The side port is a 4 inch angled dust port,,, commonly available at woodworking outlets. The dust chute just below the table is a metal magnetic dust chute I picked up at Lee Valley. It just attaches to the casting with it's magnets and I pop it off for maintenance of the bandsaw or blade changes. Most of the hose clamps are the quick release type so when I need to fully open the door I can release the bottom hose easily.
I re-routed the 2 hoses to make a bee-line for the DC trunk which goes directly below the bandsaw to the next level down. Trick is to minimize the distance to the DC and eliminate as many tight bends as possible.
Norman
Nice play on words, Jim
Nice collector, too. Simple and effective. I'm guessing you need to remove it for angle cuts?
Alan in Little Washington (NC)
While I am not adverse to cutting machinery (like a hole in the lower wheel cover) I made my bandsaw dust collection without doing so.
I made a sheet metal shroud that envelopes the front of the lower blade area. The shroud transitions to a 6" DC hose and attaches to a piece of ply that slides on two pieces of angle. The angle is installed between the fence rails using the same holes. I can still tilt the table with this setup.
Table can still tilt:
Angle iron brackets attached to table:
Shroud mounts to piece of ply that slides out when I need to remove shroud.
FredD
A good installation Norm , I am happy with just the bottom port , you must be hysterically happy ;-))
FredD
Dominic in Buck's County PA
Doug,
Check out this article I wrote:
JET BANDSAW UPGRADES
There is a link in there to drawings for a under the table shroud based on Jim's concept.
While I don't have that bandsaw any more, I made the same shroud for my Jet 18" bandsaw. With my dinky 1 HP duct collector and a short run of 4" PCV pipe I found that the shroud makes a HUGE difference. The lower guides are kept clean. The dust at the table is still there. But not quite as much when I didn't have the shroud.
See ya around,
Dominic
