A55 Smoothing Plane
Question working MDF
Bill Tindall
I have never worked with this stuff before.
I need to make a curved part that will be veneered (architecture project). Can it be faced glued like wood- wood glue and clamps. It seems porous so is more glue called for?
Shaping? What is best to fair a band sawed curve- plane, rasp, sanding? Can a curve be pattern routed, ie can the stuff be routed with straight bit router and leave a relatively smooth edge that can be veneered?
Re: Question working MDF
Bill, First, dust. Did I mention Dust? This stuff is dust glued together and if you cut it in anyway, you get twice as much dust as they used to make it in the first place.
It face glues well. Just use a coat of yellow or white glue. Be sure the joint is wet when you clamp it up.
I have milled it with ordinary router bits and it cuts cleanly and takes detail well.
You can take a thin piece of wood that will bend and conform to the shape you want and glue sand paper on it, making a flexible sanding strip and fair curves with that. A drum sander works well. I don't have a disk sander, but I am sure that would work also.
I made a pattern for gluing up laminated curves and what I did was make a single thickness to the curve I wanted. Then I glued successive layers to it and tried them to match the shape with a router bit with a flush trim bearing. I used about five ply for mine. Worked well. You could also make a pattern out of anything that suits you and use the patterning bit to copy the shape onto the MDF.
Don't get it wet, it swells dramatically.
Be careful about dinging the edges. The edges are tender. They sell the sheets 49 by 97 because the edges are tender.
The dust really is nasty. Set up good collection and wear personal dust protection as well.
Routers work great
Carbide bits are best. Gluing shouldn't be a problem, although you ought to make sure the edges are well wet with glue, because it will get wicked in and starve the joint otherwise.
exactly what I need to do....thanks
Bill Tindall
Now I know it can work.... remains to be seen if I can make it work.
Clint Searl
Good advice, Barry
Clint Searl
Clint Searl
Re: Routers work great
Clint Searl
And if you don't need a pilot bit, a 1/2" solid carbide downcut bit will keep some of the dust out of your face.
Clint
Clint Searl
I meant a spiral bit
Clint Searl
Jesse Cloud
Ditto what Barry said. When you are fairing the curve, if you make a mistake, Bondo is your friend! It will fill any voids or build up any low spots and it sands like cutting warm butter.
When I am building depth onto a form, I make the pattern, use it to mark the shape on another piece of mdf, cut it a little oversized with a bandsaw, then screw it onto the pattern. Then I run a pattern bit around the pattern, unscrew the assembly and put one copy away for safekeeping (backup). Then I make two oversized pieces and glue & screw each to one side of the pattern. I put the pattern bit in a router table, set the bearing to ride on the pattern in the middle and cut the bottom piece. Flip it over and cut the other. Repeat as needed and you can make just about anything.
Did someone say dust!
Bill Tindall
Oh my, I am thankful I used the router that has the fan the blows down. Thanks for the suggestions that worked out fine. Now to get the assembly veneered.
Before I had a DC.....
I used to make a cut and hold my breath. Then I would run outside and let it settle.
There are a lot of good things about the material, but dust is not one of them.
Glad it's going well for you.
