Band saw tires- Help
John Veerkamp
I have an old Central Machinery three wheel bandsaw. The wheels are 6 1/2 " dia. Does anyone know where I can get new tires for this machine? The saw is very handy for small projects and I'd like to keep it going.
Thanks,
John
Re: Band saw tires- Help
Low-tech solution
John, this is straight from the hip: If you can't find a real tire, try using a section of a pneumatic tire tube (assuming they still make them). If you want a crown on the wheel, you can probably build it up with tape or something before you stretch the tire onto the wheel.
I haven't ever attempted this particular fix, but I've seen some pretty rough-and-ready bandsaw fixes over the years, and this wouldn't be too far-fetched at all. I've had bandsaws that ran fine with plain flat rubber tires, so I don't see why it wouldn't work. I use spray adhesive to keep the tires from slipping.
Dale Lenz
Re: Band saw tires- Help *LINK*
Dale Lenz
John,
Check out the link below. Look at the 3 wheeler listing, they claim to custom make bandsaw tires.
Good luck
Bandsaw tires
John Veerkamp
Thanks,
The link you gave me was to Sulpher Grove Tools. They had what I needed for a reasonable price. They shipped today.
John
Dale Lenz
Thilled I could help, Enjoy!
Dale Lenz
