Function vs Art
Dave Paine
Ellis had a recent survey about whether we consider our work to be functional or art.
I responded my work so far has been functional, but I try to include more artistic elements.
Example in the picture. A friend asked if I could create a Cribbage board, and provided a "Go-By" from a craftsman, David Levy. Nice looking board, and his website has more interesting pieces.
The function aspect is the required set of holes. Turned out the "Go-by" had non-standard holes. I drilled first set at 3/16in diameter, then bought the pins and found they are designed for "standard" 1/8-in holes. I preferred 3/16-in since the pin height felt better to me.
So I had to cut out the 3/16-in holes, and "patch" the board with pieces of bubinga.
Board is cherry with bubinga, black walnut, lacewood, hickory and padauk inlays.
End pieces are maple with rosewood accents.
The end knobs are pine and the only pieces stained. The pine beads have 3/8-in dowels inserted and cover the storage of the pins, which is 3/8in x 3in deep holes.
The friend liked this result better than the "Go-By".
Function vs art, you decide.
