200+ woodworking book reviews
Dock Finish
Dock Finish
Bart Goldberg
Dock Finish
Bart Goldberg
Hi All,
I am looking for recommendations for staining/sealing a boat dock. The latest Consumer Reports on deck stains likes the Behr product, but I am not sure if the coatings for decks would be the same for docks. Anyone here have any experience with docks? The dock I'm referring to was replaced last year and has not yet been treated. It is made from pressure treated Southern Yellow Pine and sits in the Miami area and is subject to full sun and salt water spray.
Thanks
Bart
Re: Dock Finish
Re: Dock Finish
I won't speak for the finishes - except to suggest a marine spar varnish.
I will suggest "Shark Grip" - this is a micronized polymer spherical additive. You add it to the spar varnish for a non-slip surface.
Re: Dock Finish
Jim DeLaney, Austintown, Ohio
Re: Dock Finish
Check out the Sikkens line of sealers and preservatives. You'll want a penetrating sealer, not a varnish - unless you want to be sanding and re-varnishing at least once a season. Your climate will not be kind to any varnish.
Cetol Australian Oil might be another one to consider.
Jim D.
Re: Dock Finish
Re: Dock Finish
Mike in Southern New Jersey
something to consider. I've used it and it does last although something to add grip would be a good idea, http://www.fpl.fs.fed.us/documnts/fplrn/fplrn046.pdf
Re: Dock Finish
Jesper, Denmark
Re: Nothing at all.....
Jesper, Denmark
You do not want any finish that makes the dock slippery when wet, so as the boards are already PT - you should not add any finish or stain.
Re: Dock Finish
Re: Dock Finish *LINK*
That Florida sun will beat most anything up in rather short order so I'd imagine that the boards are showing checks and feathers already. My suggestion is, therefore 2-fold.
Step 1: Using knee pads, "smooth" out the top surface with a disc sander, 4" or 7" with 36 grit discs. No, a belt sander is not a substitute. This will both remove the top layer of sun-damaged wood and give the boards some texture from the swirl marks.
Step 2: Apply a non-film forming pigmented oil-based stain. I suggest Penofin Marine Oil. This is fairly easy to maintain as recoating involves simple reapplications. You do have to follow directions carefully, however, in that the surface must be wiped off after about 15 minutes, so work a section at a time, let sit, wipe off and then proceed to the next section. Failure to wipe it off well can result in a tacky surface that then must be scrubbed with a brush and detergent to remove the excess.
Penofin
Re: Dock Finish
Re: Dock Finish
mamc
I researched this very question last year with the construction of a new cedar 10' x 24 ' floating dock.
Thompsons water seal is akin to using your money to start a campfire.
Varnish /Stain including spar means maintenance, and sharp edges when it cracks, and it will, having used it for years on Muskoka chairs. Also not so good for the water when it runs and it will.
It also can mean slippery unless some grit as was suggested is used.
The key to preserving the look of the dock is UV protection.
There are UV protectors out there but I have not found anyone who is prepared to rave about their effectiveness unless they are very regularily applied. No thanks
After discussing this with fellow cottagers who over the years have tried to preserve that just built look for their docks, all had failed, and it was clear that any attenpt would be just a delay tactic and not likely successful long term.
After much consideration of all the things I could do to make my dock look like a fine piece of furniture for years to come, the final verdic was to forget about it, grab a beer and a chair and watch the loons while the dock gracefully aged and turned grey....like me.
It was the right decision.
Re: Dock Finish
Bart Goldberg
Thanks For the replies
Bart Goldberg
Thanks everyone for your replies.
I guess th4ere is not a simple solution to this situation -
Not sure if I will advise my dad to just leave it as is.
Regards
Bart
