THE WOODRAT IS BACK!
Johnsons Paste Wax.
Johnsons Paste Wax.
Johnsons Paste Wax.
David Frame Jr.
Hi all,
Last night, I went to Home Depot, Lowes and several other stores to buy some Johnsons Paste Wax.
When I got home, with the first can, I opened it only to find the was gray. Thought to myself that this
wax is bad. I brought it back to where I bought it and opened another can. It was the same as the first.
I went on a search looking for a can that had that orange, amber look. But to no avail, I was not able to
find any. After giving this new formula a try, for some reason it would not hazeover and dry like the
original Johnsons Paste Wax.
Does anyone know what happened to Johnsons Original Formula and does anyone know where I can get
a few case. If not, what are your recomendations on another wax.
David Frame Jr.
dframe01@hotmail.com
Re: Johnsons Paste Wax.
Clint Searl
Butcher's (brand) Wax
Clint Searl
Daves Not Here
If it doesn't haze over and dry like the orange formula then what does it do?
I haven't used it myself but have seen others recommend the MinWax paste wax.
David Frame Jr.
Hi Dave's not here,
The new Johnsons paste wax does not haze over, nor does it get hard. After hours of applying it,
Johnsons paste wax is still soft.
FredD
Return the unused portion and get a credit towards a can of Minwax Finish wax.
FredD
Minwax brand is the way to go. Works great.
Marv
I've used Bri-wax, Butchers, and Trewax
John in NM
All worked fine. Butchers Boston polish is probably closest to what you're used to with Johnsons.
Bart Goldberg
Bart Goldberg
I have had great success with Briwax - sold at Woodcraft.
Bart
Lee Grindinger
Paste wax
Lee Grindinger
I used Trewax for years, but paste waxes are pretty simple with the key being the carnuba. The rest of the stuff is there to make the carnuba, a very hard wax, workable. Ace Hardware sells Trewax.
Lee
Re: Johnson Paste Wax.
Al Stokka - Cambridge, Iowa
David,
I would get S.C. Johnson's phone number (or e-mail address) from their web site and communicate directly with the company regarding the can you bought. They are very helpful folks. It's a family owned company and care about their customers and products. For the record, the name of the product is "Johnson Paste Wax." No "s" at the end of "Johnson." Just one of my pet peeves.
Order direct from S.C. Johnson if you can't find it at grocery or hardware stores.
From an e-mail from S.C.Johnson:
"If you are unable to purchase the product from Lowes, or any other
hardware store, you may order it directly from us.
I am sending you an SC Johnson Mail Order catalog in case you would find
this service of interest. For on-line information about this service, you
can visit our mail order pages on SCJBrands.com at:
http://www.scjbrands.com/docs/menu/mailorder/mailorder_content.asp.
Orders can be placed by mail, fax or phone. If you would like to place a
credit card order before the catalog arrives, you can call our Mail Order
staff toll free at 1-800-848-2588. They would be happy to help you have
JOHNSON� Paste Wax delivered right to your door!"
Al
Briwax
Howard Acheson
You need to be careful with Briwax. They make two versions. The "Original" uses toluene as the solvent which is a very aggressive chemical which can damage finishes less than a year old. The Original Briwax is formulated to be a restoration wax used on old or antique items. The toluene dissolves the years of gunk as it applies a new coat of wax. Toluene is also a chemical that has some serious health issues.
In the early 2000's Briwax began marketing a non-toluene solvent wax. They use mineral spirits just as most other manufacturers. It's labeled as "Briwax 2000". That's the version to use for newly finished work. Like the Briwax Original, it comes in a number of colors.
Bart Goldberg
Re: Briwax
Bart Goldberg
Interesting - I am sure I have the original in both uncolored and colored.
I did use it on top of some recently completed work that was finished using several coats of Minwax Wipe On Poly.
I did not notice any negative effects - I guess I will need to keep an eye on that.
Thanks
Bart
David Frame Jr.
Thanks to all for your feedback on the S.C. Johnsons Wax.
I called them today and all that was said about the wax was that the dye had been taken out.
All of the patterns I put the new Johnsons wax on have yet to dry and leaves a residue on ones hands.
Tomorrow, I'll wipe the patterns down with a little laquer thinner and try some of that Minwax Finishers
wax.
By the way, the reason I use wax on my patterns is so that the double face tape does not tear off the
veneer off the plywood. I've tried to use MDF for patterns, but with very little success. The patterns
always seem to come out fuzzy after sanding them. I suppose it has to do with all the humidity here in
Louisiana.
Thanks To All,
David
FredD
Use Mineral spirits to remove the wax Dave, much safer then using Lacquer thinner .
FredD
