Sealing Sandstone OT
Barbara Gill
Someone gave us a sandstone sign for our store; what is the best product to use to seal the stone?
Re: Sealing Sandstone OT
John Veerkamp
Barb,
Tile and flooring stores carry sealers for sandstone, Marble, granite and other types of stone. Another source would be a outdoor stone and patio materials supplier.
John
Clint Searl
Clint Searl
Assuming it's not gonna be walked on or subjected to any kind of dirt, it really doesn't need a sealer. Cemetaries are full of 100+ year old untreated sandstone markers that look pretty good.
Clint
Agree....
John in NM
Shouldn't be any need on a sign. Most products are going to be intended for indoor use in any case and would probably not stand up to the UV exposure outside.
To seal or not to seal
Hi Barb,
I would agree with the others that you don't need to seal the stone, but you might want to saturate the color or deepen it, in which case there's no particular reason not to use some kind of product on it. Waterlox, oddly enough, was originally formulated for use on exterior stonework. It will soak into the stone and darken the color. There are also stains available for use on stone and concrete that will hold up fine outdoors.
I'd think of this as an opportunity to change the appearance, if you think it would improve it.
Re: To seal or not to seal
Barbara Gill
If Waterlox would work then so would the Velvit Cabin and Deck Finish. I have some clear and it would probably do the trick.
Thanks all for the information. We don't know what we are going to do with this chunk of sandstone. The stores name is Something Different. If we use the sign outside I doubt that it would be there one night before someone would steal it. Carrying it inside each night would be a chore as it is fairly heavy.
Clint Searl
Clint Searl
You could make your own environmentally correct finish by disolving beeswax in turpentine and adding natural pigment powders to tone it. It could turn into one of those little projects that helps one avoid doing real work.
Clint
Hadn't thought of that...
John in NM
If theft is a problem, graffiti probably is too, so perhaps sealing is in order for that reason or with all the handling moving it in and out.
As Ellis says, Waterlox will work and give it a darker almost wet look. Thinned spar varnish would do the same. If you don't want to alter the look, there are water based urethanes that will fit the bill as long as you don't over do it. They start to have a milky look with too many coats - a couple is really all you need. The one I've used for tile and sandstone floors is Jasco - but it seems similar to thinned Varithane diamond finish to me.
Have you thought of putting it on wheels for ease of moving? Maybe a wheel barrow type of arraignment?
Barbara Gill
I have an old planer that is from the steam belt driven era. We use an electric motor to power it but the head and feed is still driven by big wide belts. I mix turpentine, rosin and beeswax to make a belt dressing.
My main goal is to prevent anything from staining the stone. I think I will use the clear Velvit CDF to seal it since I have it.
Here's a project for you...
Hang the stone from a little crane track that goes from inside the store to outside. You could bring it in at night by a little servomotor and a cable or even one of those old long handles shaped like a brace that they used to use to roll up awnings.
Of course, you might not want your store to be incognito at night. In that case, leave the sign there, but padlock it to the support somehow.
Ain't design fun?
FredD
Any concrete sealer will do the trick . It is formulated for that purpose and eliminates experimenting .
It is available at all concrete batch plants and most hardwares worthy of the name.
FredD
Re: Here's a project for you...
Barbara Gill
LOL I don't think I neen any more projects.
Clint Searl
Clint Searl
That mix is used by artists working in encaustic.
Clint
Gary Smyth
I've a similar concern. This is very soft stone from Indonesia. A bump will cause a deep depression or even crumble the stone. It feels like sandstone but I think it is softer. It needs to be sealed to limit dust and provide some strength. I can live with some darkening, but I want to still see the grain of the stone. Will the solutions proposed here help? If not, where else might I go? Thus far I've been only to marker and headstone places. The library has not helped, nor the art department at Carnegie Mellon U. or the Carnegie museum people who want paid. A light gray relatively even in shade is what I'm searching for.
Clint Searl
Clear water borne poly
Clint Searl
Can you get a small chunk to test on?
Nathan
Hue, value and sheen
These seem to me to be the main variables here. When you put a finish on stone (or wood for that matter), it may or may not change the hue (neutral gray, cool gray, warm gray, some other hue, etc.) because of the tone of the finish itself. In the case of pigment stains, they change the hue through a combination of solid pigments and the vehicle. Products also vary widely in how much they darken the object (value). Some go on dark and dry invisible; others darken it perceptibly (as well as possibly changing the hue). Then there's the question of surface sheen, which will vary with the product and the number of coats. On soft porous stone, most liquid products will be absorbed readily, so there won't be much change in the apparent surface texture or quality. But, if you add more coats, different products will build on the surface in varying degrees, producing more of a sheen or luster with each coat.
Clint's idea of a water-borne poly sounds good to me, because it won't appreciably darken the stone or modify the natural hue (at least the brands I've used). It is also quite thin, so it will absorb well, but after the initial sealer coat, you're likely to see a progressive increase in sheen.
Commercially available concrete and tile sealers do a great job of sealing the surface and protecting it from moisture and staining, but many of them darken or change the hue or sheen of the stone or tile. A lot of customers want this effect, but you may not. That's why I'd suggest experimenting, especially on valuable pieces that you don't want to mess up.
Re: Sealing Sandstone OT-EEEEK!!!!
Justin Szeliga
How about getting a silicone sealer made for masonry & stone, water or solvent based, instead of using techniques that will greatly change stone color. Silane/siloxane is the stuff I've seen about & it does a good job of protecting stone, brick, mortar & concrete.
Just Google silane/siloxane & you'll find plenty.
Peace
Justin
Thanks Everyone!
Barbara Gill
