Apprenticeship update
Nathan
The vagaries of life intervened in my apprenticeship and I had to put it on hold for three months. Last week I went back for two days. Then more work came in so it's on hold again at least until the 15th, perhaps longer.
It was great to be back, if only for two days. The guys seemed pleased to see me and immediately put me to work. They had some "paper-core" doors and jambs from the local box store (the kind that are covered with plastic film to make them look like wood). They were altering them to make them fit in non-standard spaces in a customer's basement. One of the doors had to be cut down so much that they had to move the hinges, so there were a couple 1/4" holes had to be plugged. There was no 1/4" dowel at hand. A discussion ensued over how best to plug the holes. One of the guys was advocating the use of a steel plate with toothed holes in it - for making different diameter dowels by pounding square stock through them. But Master didn't think that would work with the hard beech ("You'd have to make the stock into an octogon," he remarked so only I could hear), and anyway, he loves his lathe (he designed and made it himself during the Communist period when small factory-made machines were hard to come by). It's a beauty, by the way - simple, solid and effective. So he cut out a small piece of European beech and quickly turned it into a dowel. Master does everything very quickly. It turned out to be too narrow because I had set the calipers wrong. By the time I found that out he was gone, so I cut out a new piece of beech and turned a new dowel to the correct diameter. Man, was that fun.
The next day almost everyone was gone installing sliding glass doors at a job site, so I essentially had the whole shop to myself. The guys told me they needed to make 200 narrow strips (1/2" x 1") for some interior doors. Instead of cutting up new boards, they asked me to go through all the scrap and pull out basically everything that was not hardwood, cut the longer pieces down on the bandsaw and and then face- and edge-joint everything in preparation for ripping. There's a lot of scrap in the shop, but most of it is hardwood. In the end I found about 60 or 80 softwood boards of varying thicknesses, many of them quite narrow, so I had my work cut out for me. I found after a few passes on Master's humongous 20" industrial jointer (the cutter block is a good 6", maybe even 8", in diameter) that I could put workpieces through very quickly and still get a relatively nice surface. Doing a big run like that, though, was somewhat exhausting and I was glad when the job was done. It'll be interesting to see the finished doors - apparently, they will have these thin boards spaced closely together in lieu of panels.
Thanks for letting me share.
Nathan
Re: Apprenticeship update
It's fun to hear your stories
You're most welcome to keep us posted on your exploits, Nathan. Your observations take me back to episodes in my own woodworking life where I learned the same things, or variations thereof. It also gives us a chance to fill in any blanks that Master has not addressed, so don't hesitate to ask questions; but, as a loyal apprentice, let your Master's word be final.
Ellis Walentine, Host
George Colonel's Workshop-Havertown PA
Good Morning Nathan,
I enjoyed your account, especially about the lathe incident. The Master and I must be related somehow. I can't imagine turning a correctly sized dowel on my lathe. Keep your reports coming.
George
Just use polyurethane glue, right?
Nathan
At the shop, when a dowel or tenon or whatever turns out to be too small, I've seen the guys use polyurethane glue, which expands to fill the gaps. In a world of ideal craftsmanship, you wouldn't do that. In a commercial shop, though, time is money.
My dowel was the correct size, but it took me at least 4 times as long to turn as Master's. I took it off the lathe and put it back on three times I think. If Master were paying me wages to be in his shop, I don't think he'd be pleased.
Re: Just use polyurethane glue, right?
FredD
Good to hear from you again Nathan, I wondered where you went.
Speed at production comes with practice and repetition, and always remember a job done right the first time is always faster regardless of how long it took.
In my opinion ,using glue for gap filler is not a good practice.
It promotes sayings like" that's good enough for Government work" or "that will suit the girls I go with" ;-))
FredD
