pipe closeer
pipe closeer
       pipe closeer
del schisler
why couldn't they have cut the big unit that they first tried Didn't work Why couldn't they cut it in half and took it down and put 1/2 on each side and used cable's and drawed it tight over the pipe ??? Of course i am not their I bet their will get out of paying for all this They will take chapter 11 or some other thing What the gov. should do is have them put in a fund a couple billion Non refundable Just to cover cost ? Probly not going to happen Oh well the gov. will get in the end ?
Re: pipe closeer
Moses Yoder
Re:        pipe closeer
Moses Yoder
Del, I think you should volunteer to help BP finish this up. They could really use someone who knows as much as you do.
Re: pipe closeer
Re:        pipe closeer
Dave Bair, Eaton Rapids, MI
I thought they should crimp the pipe; just crush it flat instead of shearing it. If it didn't seal it off completely, it should slow down the flow. I'm sure there's reasons this wouldn't work, I just don't see them.
Re: pipe closeer
Lee Grindinger
just a guess..., but
Lee Grindinger
I'm guessing the pipe is too brittle to crimp. While the pipe is strong it's not able to flex well, kinda like the difference between carbide and aluminum.
Lee
Re: pipe closeer
Re:        pipe closeer
Joseph Mulherin, Sr
My question about this oil blow-out mess:
There are some ships over in the Saudi Arabian area which hold about 1M gallons, and they have the capability to suck up the oil and water, separate it out about 97% and return the water overboard and keep the oil on the ship. They could have about six of these ships cruise the Gulf sucking up the oily water and plumes, take off to off load the oil at shore refinerys and return to get another load. WHY are NOT these ships being used?????
And, where is any knowledge available of the Kevin Costner equipment which is supposed to do the same thing???
