We value your privacy.
I want to sand my dining area hardwood floor. It is Bruce prefinished flooring and has small vee grooves. The finish that came on the floor was thin and not durable. I foolishly thought it was some sort of super tough industrial finish. NOT! Had I known how pitiful the finish was, I would have screen it and applied a real fish from the beginning.
So, now I need to sand it. That means sanding away enough of the floor to eliminate the Vee Grooves. (I wont miss those little crud catchers). The problem is that the flooring runs up under the tow kick of my kitchen cabinets. Any one got a good idea how to sand off a 1/16" of oak under the toe kick? Is there a machine I can rent for this application?
I think you'll also find that it is A LOT of work to sand out v-grooves. You may have a place or two where you get to the bottom of a groove, but to do it over a whole floor is about like doing a full refinishing schedule of sanding 3 times over.
Got a better idea? What do I do about the Vee grooves? Is there a practical (Easy) way to deal with the grooves? I have about 75 of them 15' long. I suppose I could hand scrape them. Or set up a router and recut the grooves? Any suggestions?
What I've done with v-grooves in the past is just hand-scrape them. It sounds like a lot more work than it really is. You don't HAVE to scrape off all the finish (and stain, if present)--I did it mainly to clean up the groove. The grooves will always appear darker than the rest of the floor anyway.
Have I ever mentioned I'm a fan of installing unfinished hardwood floors then finishing them? I suspect you might be coming around to my way of thinking about now, too. One reason I like them is that when you do sand and finish them, you get a relatively flat, SEALED surface, which you can't get with pre-finished flooring, particularly with micro- or v-grooves.
OH! Believe me, I absolutely agree. I have put down acres of unfinished hardwood and had it finished. This is a case where the in-laws gave this floor to my now ex wife and I installed it because I would have been an out cast if I had not.
I do home Inspections for a living and I tell everyone moving into house that has this type of flooring they should screen it and apply a serious finish before they move in.
Well Barry , you do have a problem, probably one you could have avoided if you had checked into the various companies that make hardwood flooring.
I. Bruce is a old line Floor Finish company , it never made flooring , it had Mills do that and the quality varied greatly with the source.
Contractors never recommend this company for that reason.
2. You do people who apparently rely on you for correct information a disservice by telling them a Prefinished flooring is worthless and should be refinished , maybe yours was , but the vast majority are not.
3. Prefinished flooring, Vee-grooved and end matched has a superior finish on it , that you can't approach in the field , for toughness and durability.
I am talking exclusively about that type of flooring, many people like the look and it has the advantage of less mess installing in a occupied home.
The Vee-groove and end matched look was developed to avoid high and low joints in a prefinished stock, if you want edge matched , the best way is the traditional sanding and finishing after installation which needs to be done while the house is being built , rather then a remodel after the fact job.
The Vee-Groove and end matched type of Prefinished flooring also avoids the snap , crackle and pop you hear when you first start living on a new edge matched , finished in the field flooring that comes from the flooring flexing while you walk on it and breaking the finish between the boards.
You may on second blush want to put down a new floor after removing the old one, the work involved isn't much different , but the look sure would be,
You say Bruce was FINISH company that also manufactured flooring though subsidiary companies. (Similar to General Motors is a Retirement Plan that occasionally makes a car?) You would think it would have been the flooring that failed. But In my case it was the finish. The part they did in house failed. In a few months.
I tell people they should check with experts on flooring and see if it would make sense to upgrade the finish. While the house is empty.
I may have been unclear again Barry , but let's try again , Bruce made Floor Finish, and they sold though place's like Home Depot, flooring that was made in a flooring mill by various companies and at least in the Home Depot was packaged and sold as Bruce flooring even though they didn't make it.
I installed a floor for a client that was familiar with the name and advertising of Bruce and really wanted the flooring to come from Bruce and they were going to purchase the amount I said they needed from Home Depot.
Well I said give it a try if your Heart is set on it ,but I personally as a Contractor will not guarantee it and the contract will read , Client furnished material.
After a three week wait , they were given laminated flooring instead of the 3/4" solid stock , I told them it was a rip off and they were paying the full price of 3/4" solid Oak flooring for something entirely different and poorly made.
Home Depot surprisingly corrected the mistake and furnished what she wanted from a different supplier.
