Painting Particle Board
Bill Lordan, Auburn NH
In an earlier post, I mentioned that I was building a hollow arch arbor for my daughter's graduation. Because of the dimension given me, I will need to purchase 4 sheets of plywood. The arch needs to be 5' long and 34" tall at the top of the arch. I am not being reimbursed so I hope to create the arch as cheaply as possible. I hope to use particle board tp create this 4" wide arch. My question concerns painting. Will the particle board accept paint? I will be using an HVLP system (Fuji) to spray the arbor; can anyone recommend a specific paint to use, I am looking for a gloss white effect? TIA for any guidance you can offer.
Bill Lordan
Re: Painting Particle Board
I would prime the particle board - Kilz works well. You can do a single coat of Kilz (original) and then one or two coats of paint.
I don't like using oil based paint and there are a lot of good gloss interior/exterior latex paints out there. I prefer Benjamin Moore - but there are other good ones.
