groves
mark
how do I cut a V groove in round stock?
groves
mark
Re: groves *LINK*
del schisler
here is the web site for the V grove ? not much infomation You did want V groves and Not flute ? You use a router in a table with fence ? How big dia.? http://www.google.com/products?hl=en&q=v+groove+router+bits&um=1&ie=UTF-8&ei=Xd4GTJn5KsSBlAfVgNHKCg&sa=X&oi=product_result_group&ct=title&resnum=3&ved=0CE4QrQQwAg
Re: groves
If you would like to do it by hand (and your piece is small enough) - I usually use a saw to cut a kerf in the piece. I then use a rasp (coarse then fine) or the bottom of a microplane rasp to rasp the piece. I usually do diagonals and what is called "barley" twists.
Makes great candlesticks and ornaments for bed posts.
Re: groves
steve mackay
If you mean length-wise I lay it on my non-stick assembly table and glue a square block perpendicular to each end. This holds the dowel "square". When its good-n-dry run it through the table saw.
Re: groves
Joseph Mulherin, Sr
I would have to agree with Steve about glueing a block onto the ends, but I would run the dowels thru on the router table like Del said. It al;so depends on how long the dowels are before deciding on which to use for grooving...and the size of the dowel is also important.... but whichever you decide to use....be most CAREFUL with your fingers...use the standoff handles for safety.
Re: groves
del schisler
use a router and a v grove bit Not much information ? Here is the bit needed
Re: groves
AS you can see, we need a little more info. Did you mean lengthwise or around the perimeter? Or in a spiral? How big is the round stock and how long? Is this a finished groove or something like a slot in a dowel to let the air escape and once it does its job will never be seen again?
Might be good to describe the project a bit and give us an idea of what tools you have that might work for this. Router, router table, table saw, hand tools? And do you still have all ten fingers and want to keep it that way?
Re: groves
mark
Barry The groove would be lengthwise down a 1 1/2 in diameter piece of stock about a foot long. I want the grove to fit around a 45 degree corner. I have plunge router router table table saw scroll saw fairly well equipped shop. No band saw. Yhankyou for responding
Re: groves
Mark, You have several options.
If your "dowel" is 1 1/2" in diameter, you could set the fence on your router table 3/4" from the center of bit with an appropriate angle on it and raise the bit to the height you want and make the cut, being careful to hold the piece steady and not rotate it while you slide it over the cutter.
It would be easier and probably safer to glue two 2 X 2"s, one on each side of your dowel. They don't even have to be exactly the same size as the dowel. Just set all three on a flat surface and glue them with hot glue or even double stick tape. The bond does not have to be fierce, just strong enough to hold the dowel still long enough to make the cut. You could angle the blade on your table saw and do it in two passes.
You could also clamp the dowel between two 2 x 2's as above and use a hand held router with a fence.
Did you mean a 45 degree corner or a more common 90 degree corner?
