Another Question on Deck Rail pickets
In my questions below, I propose using copper clad ground rod as deck rail pickets. While at a Borg I found they have Aluminum pipe set up as pickets. The pieces are 26" long and abut 3/4 in diameter. You buy end plugs that screw onto the top and bottom rails and then insert them into the pipes to create a rail.
They come in Black and Bronze and are painted or powder coated.
Anybody used these?
Any idea how long the paint/coating will last? (I want this to be my LAST deck rail.)
Re: Another Question on Deck Rail pickets
Keith Newton----Little Rock, Arkansas
Barry, One thing that I have found that works good yet pretty economical, is to use 1/2" galv. conduit. It cuts easily, and is holding up pretty good after 5 years.
Should paint good if you wash with vinegar, but I left mine raw.
In the bottom rail, I may only drill a hole 1.5" deep for the tube, then finish drilling through the bottom with 1/4", so it can drain.
Keith, are you talking about EMT, the really thin wall tube or the type you can cut and thread? Not sure the local EMT is Galvanized. What does yours look like after exposure to the weather? Sort of Dull gray?
Its funny you mention the drain holes, I had already decided I would do that. I was just trying to decide how big they should be.
Barry, I used that at my cabin, in 2005
I am down there now, and they look fine with treated pine. I will try to email you a pic later.
be sure that you choose your boards that you are going to drill, from the best boards in the lot. Since they are usually spanning a long way, they will warp if there is any deviation in grain or reaction wood.
Bill Wilkinson
I used them on my deck - they are great.
you need to drill the sockets precisely into the top and bottom rails - I believe the plastic caps need 13/16" holes.
they look great - your eyes look right past the black ones - they do not block the view very much.
P.S. I have an excel spreadsheet to calculate the distance optimized to be 4" between max, while leaving a proper space at the ends... I will supply later from home.
