Drilling Accurate pairs of holes?
I am rebuilding my deck rail. I want to use sections of copper plated rod for pickets. (Actually, copper clad ground rod 9/16" in diameter, cut into pieces 30" long.)
I want to drill holes in a top and bottom rail and insert the rods. So, I will be drilling into the edge of a 2 x ?. The top and bottom holes need to be drilled accurately left to right because if not, the pickets will be poorly spaced and out of alignment. The holes will be on four inch centers so it will be easy to see if they don't match up.
One though I had was to set up my drill press and drill through the edge of a 2 X 6 every four inches. (Use some sort of indexing device) Then rip the board and use one half for the top and the other for the bottom, that way the holes would surely Line up.
I don't have a doweling jig, but I was wondering if this were a good application?
Anybody got a better idea?
Re: Drilling Accurate pairs of holes?
I like your approach
Terry Alexander
Pretty smart about drilling both edges and then ripping the 2x?. Indexing? I've done this a lot.
Take a piece of 3/4" plywood and drill a 9/16" hole. Glue in a 9/16" dowel. Position this however many inches from the center of your drill press. Drill the first "pair" of holes with the 2x? butted up against the dowel. Move the 2x? down and set the just drilled holes on the dowel. Repeat until all holes are drilled.
Perfectly spaced!!
Terry Alexander in West Texas
Re: I like your approach..Question
You propose to drill in from both edges?
My thought was to drill more than half way through, rip the board and use the piece with the holes all the way through for the top. That way, the cap rail would cover the holes and you could insert the pickets into the top hole and lift them up enough to drop them into the bottom hole.
(As an aside, I made a bed that had 36 pickets for the head board. I did not think I was going to live long enough to to manage to get all of them into the holes on both ends all at once.)
FredD
Barry, you asked how to accurately space holes for pickets and Terry gave you a good way to go about it.
If you were to drill that many holes in a 2x all the way though, four inches O.C. I would think the rail would be greatly weaken.
FredD
I use a plunge router with guide bushing
Keith Newton----Little Rock, Arkansas
You can use a router bit, but I like end-mills. They will drill as fast as you can push it down.
Make a template with holes the size of your guide bushing, then chamfer the top edge to make it easier to find with the bushing. I can drill and locate the next bushing in about 1 second per hole.
Make the template as long as the longest space between post. Some will need to start centered on a hole, some half way between to end with the best space at both ends.
You can attach an edge guide to it to clamp to the work, or you can screw it on.
Nothing drills holes as fast as a plunge router.
Joseph Mulherin, Sr
Barry, I would apply a piece of pegboard to the side you are drilling into with some double adhesive tape...drill the holes thru the 1/4" pegboard holes which will make sure they are the correct spacing. Then I would trim the end of the railings to fit the appropriate space you are putting them into
I thought about that, Fred, but...
My plan is to drill through the top piece and into the bottom piece about an inch, leaving about 2 1/2" of it solid. The top piece would be about 2 1/2" wide and would be screwed securely to the under side of the cap rail, reinforcing it. This would make the top holes twice as deep as the bottom hole so that I could lift the pickets into position the same way you do a sliding door.
I started out with the idea of using copper pipe or even plastic pipe. I was afraid the pipe would bend if someone took a header against it. I like the ground rods because I think they would be strong and because they are copper clad, not rust. I also kind of like the idea that they would be individually removable, just in case, but I have a grandchild on the way and my assumption is that she will sit there and remove the pickets and then fall through the hole. I may put a screw in each one to prevent them being removed.
Re: I thought about that, Fred, but...
Dan Donaldson
I would bet that with the length of the pickets and the fact that they are in holes at both ends, copper pipe would be plenty strong. I think that if you were to hit them hard enough to bend them, you would have worries other than the pickets bending, like a severe concussion. The ground rods are plated, but if you get a scratch in the plating, you will get rust, and they are pretty heavy to cut and work with. I would mock up a piece with the pipe and see.
FredD
The plating going to hell om gorund rods was my thought also Dan, I believe Tempered copper pipe sold in ten foot lengths would plenty stiff enough for pickets, would turn a pretty shade of green and never need painting.
In addition it wouldn't have a Blacksmith made it look ;-))
FredD
