Anyone made their own receptacle covers?
Stephen Kirk
We're finishing up our kitchen remodel which was a new countertop, tiled backsplash, new sink/faucet, new hood. Instead of cheap looking electrical switch covers, I thought it would be nice to make one wooden ones. Has anyone done this? If so, any tips or tricks, other than trace an existing one and cut it out?
Re: Anyone made their own receptacle covers?
John McGaw
I made some years and years ago. I made a template and routed the bodies -- receptacle plates were easier than the switch plates as you might expect. I beveled the front surfaces using a sander although a table saw might be easier. IIRC the most touchy thing involved was the back of the plate which must be relieved to fit the receptacle or switch. Stable wood is going to be a requirement since, unless you want really chunky plates, the material is going to be very thin and prone to warping.
Re: Anyone made their own receptacle covers? *LINK*
Lee Schierer McKean, PA
Years ago I made my own. I used a router and a template for the openings and the back reliefs. It was a lot of work. Do an internet search and you'll find them in many types of wood already made. Here's one source.
Wood outlet/switch covers
Laminate them
Years ago, I did dozens of them for an addition we were finishing. I laminated them from two layers of 1/8" Brazilian rosewood on the outside and a layer of cross-grain 1/8" Honduras mahogany in the middle -- essentially a 3/8" plywood made of exotic wood. Then I used my pin router and templates to cut out the various shapes and patterns - 2-gang, 3-gang, switchplates, etc., and I backed out the backs with another pin router template. You can do this with a hand-held router and a shop-made fixture.
I have one of these things lying around somewhere. If I can find it, I'll post a picture.
FredD
I have made them and the problem was getting a metal backing which you need for wood receptacle covers. One day I was in Dale Hardware in Fremont , Ca. and lo and behold they just got in a full line of covers in Oak, Ash and Walnut and natural unfinished ,so you could match cover wise with stain.
Never looked back , I have bought them by the dozen.
FredD
Alexandre Grigoriev
What you said. I'm afraid the previous posters have their plates non-compliant with the fire code.
When I needed those, I bought some unfinished ash plates cheap at walmart, stained them to my liking and pu in place.
Moses Yoder
Moses Yoder
woodwallplates.com is the source we use for all our wood switch plates. Highly recommended.
Moses Yoder
Re: metal backers?
Moses Yoder
I think the code might be different in California, but as far as I know we do not need metal backing plates on any outlet covers in Indiana, Michigan, or Illinois. Perhaps the inspectors are just being lax in their duties?
Re: metal backers?
Dan Donaldson
May not need to be metal, but probably have to be non-flammable, which wood is not.
A question
Gary Camp, Bend, Oregon
Are plastic cover plates non-flamable? I've never flame tested one or, to be honest ever even thought about thier flamablity. I guess I need to find a broken one and test it.
glc
