Titebond II Extend Wood Glue
Tom Rex in TX
Is this the best glue to use for a project that requires a lot of thime to get everything in place?
Is there a better glue that I should use?
TIA,
T Rex
Tom Rex in TX
TIA,
T Rex
Re: Titebond II Extend Wood Glue
George Colonel's Workshop-Havertown PA
Good Afternoon Tom,
I'm not quite sur.te what you mean by "a lot of time". You could use liquid hide glue, which allows plenty of time to align and clamp. Its also very strong. It doesn't like water well.
George
You could use Plastic Resin Glue, Epoxy, or Liquid Hide Glue. All have a long open time and in some cases a long clamp time.
I find it best to make a practice run on my complicated glue ups. Assemble it dry and get the clamps positioned and all set up. Cool the shop. See if you can break it down into sub assemblies to see if you can do the glue up in stages. Get an assistant to help.
Epoxy
Barry says, "You could use...Epoxy..."
There are several different formulations of epoxy with varying open times. The good news for your project, if you decide on epoxy, is that, in general, the longer the open time, the stronger the bond.
Re: Epoxy
Ditto on epoxy. I use West System epoxy and have 2 different hardeners that change the open time. The slow set stuff has all the open time you could want. You can mix thickeners with it if it's too thin.
I've also uses System 3 slow set epoxy and it works quite well.
Practice your glue up. That way you can see how long it's going to take and solve any clamping and alignment problems. I've been using titebond ll for a long time and really like it. I know it's taken me more than a minute for some complicated glue ups and I didn't have any problems. However whenever I'm in doubt I go to the epoxy, you could stop and go to the bathroom in the middle of a glue up with that stuff and not have a problem. OK maybe that's a little extreme but you know what I mean.
Re: Epoxy
FredD
"you could stop and go to the bathroom in the middle of a glue up with that stuff and not have a problem. "
Guess it depends on whether it's a one or two ;-))
FredD
And how good the reading material is
