Dealing with the sapwood on black walnut
David Frame Jr.
Hi all,
If anyone has any information on how to stain, dye, glaze, or tone the sapwood on black walnut, I would be grateful.
I do not want color the whole piece, just the sapwood and have it match the natural color of the wood unfunished.
Is it possible to soak some black walnut sawdust in water or some other chemicals to get the color I'm looking for.
Thanks for your time,
David
dframe01@hotmail.com
Re: Dealing with the sapwood on black walnut
Gil Jones
Take the outer husks of the walnuts, removed from the nuts, dried, then soaked in a 50:50 mix of water and household ammonia (the kind with no soap or perfume) in a closed container. I let mine soak and leach out the beautiful walnut color for a few months, then strain and filter. You now have a water base stain or dye that is a lovely chocolate brown.
Gil
I usually just "flaunt" the sapwood. I like the contrast of light and dark. I do understand the desire to mask it though.
I usually like using Transtint dyes to unify colors on a piece. You can add dropwise to your dyeing solution (I usually use isopropyl alcohol). Woodcraft, Rockler and others have Transtint and similar dyes. They are not cheap - but a little goes along way. Arti-color is also supposed to be good, but I haven't tried them.
Jesse Cloud
Do you intend to leave the piece unfinished? The problem would be that the unfinished wood will change color with age and exposure to light in a different way than the died wood.
Many dyes are pretty fragile and will rub off unless sealed with shellac or a topcoat.
I usually dye and glaze (glaze is just stain or dye on top of a sealer) all the walnut, but the dyes will blend the sapwood in nicely. Try burnt umber and red mahogany for a nice look.
Selective staining
Sap stains are not uncommon. Back in my early woodworking days, the first Watco product I used was walnut sap stain, just a simple dye that did just what you are talking about, and it did it well unless you weren't terribly careful with it. Nowadays, you can mix your own sap stain using dyes and solvents.
As someone mentioned, sap stains are a bit risky in the longer run because of the color changes you can expect in unstained wood; in other words, the nice color match that you worked so hard to achieve is suddenly a mismatch. Happens with cherry too.
Try some home-brewed sap stain combinations on scrap until you find a solution you think you can control. Don't forget to add a coat of finish to see what it *really* will look like.
Samples are key.
Finish firewood first.
