Podium (podia??) height?
What do ya'll think a good height for the front of a podium should be??
Re: Podium (podia??) height?
Clint Searl
Podium is the (usually) raised platform that you stand on; lecturn is what Obama hides behind when he makes an important speech from the teleprompter.
Clint
Lecturn then
Carol Reed
Depends on the height of the speaker. Old time pulpits and lecterns were adjustable in height.
Given multi-vision eyeglasses, adjust-ability is even more important today.
Paul Blackwell
I just completed a lectern, and since I couldn't come up with a set of plans, I just went to a website that sells them and just used the dimensions they supply. The most common height for the front is 45 to 47 inches. One site you can check is www.bestlecterns.com.
Thanks - what angle did you use?
I was figuring about 30 degrees. I was also planning on side lips (as well as a bottom lip).
Re: Thanks - what angle did you use?
Paul Blackwell
The top on mine is 23" square, the front is 8 1/4" and the back (where the speaker stands) is 3". The angle is 15 degrees. I made mine like a school desk with the top hinged so there is storage space inside. I used a bottom lip, and put a pencil groove in the top. If you'll provide me your e-mail address, I'll send some pictures.
