What is Flitch?
What is Flitch?
What is Flitch?
Joe in a Cleveland suburb
I think I kinda know, and probably should know, but what is Flitch when talking about wood and/or logs. And what is a 'Flitch line'?
I've been watching sawmill and sawmilling videos as a member at Finewoodworking.com and that has been mentioned a few times. Specifically 'sawing to the flitch line'. Not too sure what is being referred to.
The process of taking a log, milling it, drying it and so on is pretty interesting. I always wanted a portable mill. But then I would need a truck, a yard bigger than my suburban postage stamp size yard, a kiln blah blah blah... :D
Mr. Tindall?
Thanks.
Re: What is Flitch?
Several meanings...
Lee Schierer McKean, PA
A flitch can be:
1. A salted and cured side of bacon.
2. A longitudinal cut from the trunk of a tree.
3. One of several planks secured together to form a single beam.
Lee
Re: What is Flitch?
Re: What is Flitch?
del schisler
here is what a flitch is In flitch cut boards, the wood is plain sawn, with each cut made one after the other, like slicing a loaf of bread the long way.
This method has the least amount of waste, but the quality of the wood will be inconsistent and most boards will contain both heartwood and sapwood.
A stack of boards cut in this manner, from the same log, is called a flitch. A flitch has the advantage of having matching grain through out.
also so a google search for more on flitch
http://www.google.com/search?hl=en&q=wood++flitch&aq=f&aqi=g1&aql=&oq=&gs_rfai=
Re: What is Flitch?
Flitch Lumber
is where the log is kept in a single orientation and then sawn leaving the natural edges on. You can then put the log back together (having lost only the saw kerfs). Flitch sawn lumber is, depending on the width, often sold in sets of 4 or more boards in sequence from the same side of the log.
What this does is produce bookmatched boards that can be used for table tops, doors, etc.
I have several walnut flitches, with crotches intact, in the stock I just moved into the shop from outside drying.
Re: What is Flitch?
Re: What is Flitch?
Fred Davis
While the term Flitch can refer to sequential sawn lumber from a log , whenever I run across the term it is referring to sequentially cut and stacked and sold that way as Veneer.
The idea being to have a Veneered panel or table top look as uniform as possible.
FredD
Re: What is Flitch?
Re: What is Flitch?
Fred Davis
Sequentially sliced as opposed to Rotary cut
What happened to the edit function Ellis?
FredD
Re: What is Flitch?
Beats me?
Bill Tindall
'Flitch line'? Never heard of the term. Flitch is a common term for veneer. A flitch of veneer is a stack of veneer pieces consecutively sliced from a piece of a log(cant).
I have never seen a log flitch cut, mainly because it yields a "flitch" of mostly lower grade boards that are difficult to deal with. I suspect flitch cutting a log has become popular as a result of the proliferation of portable band mills operated by novices, sawing for novices. This means of converting a log into boards is the easiest way on a portable band mill and very difficult/risky/impossible on a circular sawmill. (the problem is holding the round log with the dogs on the carriage, and the log can't be greater than about 20" diameter) Sawing this way will yield the lowest possible quality lumber from a log. Whilst one might imagine book matching lumber sawed this way, as a practical matter, it typically won't work out., unless one is striving for a rustic look incorporating knots and splits.
It does make sense to flitch cut a crotch; in fact this is the only way to cut a crotch.
Re: What is Flitch?
Re: What is Flitch?
Dave Bair, Eaton Rapids, MI
Thought it was that Chevy Chase character: the reporter who assumed different identities to get the story.
Re: What is Flitch?
Re: Beats me?
I've never heard George Nakashima referred to as "rustic" although almost all of his work involves flitch-cut slabs.
Perhaps it's my personal taste, but I prefer what I make to reference the life of the tree it came from.
As usual, YMMV
Re: What is Flitch?
Lee Grindinger
I'm not sure that's true
Lee Grindinger
Years ago Ellis and I spent some time with Mira Nakashima and it was clear that the stores of slabs were not necessarily flitch cut, but standing alone, perhaps a couple of slabs from particular logs. Mira would generally dictate how logs were sawn for her needs but I don't recall seeing logs stacked as they were sawn, the slabs stood on ends in a rather helter sketler way.
Lee
Re: What is Flitch?
Lee Grindinger
A picture is worth a thousand words
Lee Grindinger
Re: What is Flitch?
Re: A picture is worth a thousand words
Sgian Dubh
Lee, here in Europe logs that are slash sawn (aka through and through sawn, plain sawn, etc) and reassembled in the round in the same order as they were cut are known as boules (from the French). I suppose they might be called flitches, but I've only ever come across flitches of veneer as Bill described. The chances of successfully bookmatching slash sawn planks of wood to create a visually convincing sequence into a larger slab such as a table top are pretty much zero; for a start the saw kerf takes out about 4 mm, even with thenormal bandsaw mill here in Europe, and almost nobody in this part of the world uses the fairly common North American insert toothed circular saw for the job which takes out an even bigger kerf, generally closer to 6 or 7 mm (~1/4"). Slainte.
Below. Boules of European 'character' oak air drying in a commercial timber merchant's drying shed. Most of this material goes to people like car manufacturers apparently for trimming out dashboards and the like. That surprised me a bit when I heard it, but that's what the merchant said.
Photobucket
Re: What is Flitch?
Some correction
The slabs that I saw in the storage and the boards drying in the sheds at the Nakashima "compound" were cut for character and there appeared far fewer being sawn for "Grade" from turned cants. They certainly don't stack for drying in flitch "reconstructed" mode.
I have some stock sawn for grade as well, but each tree is different. My sawyer (portable mill notwithstanding) will cut for grade,"chase", quarter saw, and whatever I direct.
Re: What is Flitch?
Re: What is Flitch?
Dan Donaldson
If you do not see the edit function, it either means that you have used a different name, something happened to your profile, or you waited too long. (you can only edit for a period of time.)
Re: What is Flitch?
Did I say that?
Bill Tindall
To repeat......"Whilst one might imagine book matching lumber sawed this way, as a practical matter, it typically won't work out., unless one is striving for a rustic look incorporating knots and splits."
For those confused by the argument, let me clarify, just in case one is tempted to saw a good log this way with the hope of book matching the result.
Book matching would involve gluing adjacently sawed boards, ideally of similar width. Such boards will come from the center slices of a "flitch" cut log. Unless one is dealing with an exceptional log, as one nears the center knots will be encountered. Even the exceptional log is going to have juvenile wood at its center which invariably cracks upon drying, especially in the case of cherry. Hence, the wide lumber from the center cuts, that by size would be ideal for book matching, will in fact typically have defects in their centers, yielding the "rustic" look I described.
I included "typically" in the sentence that offended some, to allow for the possibility that one might get a book matched table top from the occasion log sawed this way. Personally, I have never sawed a log that I was willing to take the risk.
I have had success achieving a book matched look for a table top by choosing a wide board twice as long and half as wide as the top to be made. I cut the board in half lengthwise and glue it edge to edge. Because the two pieces are from the same part of the tree the grain density and color will be nearly a perfect match, but the grain pattern will not match (but it may be close).
The only reliable way to get true book match is to use veneer from a flitch of veneer.
The fastest way to cut a log on a portable band mill is to "flitch" cut it. If you have a log to be cut don't confuse fastest with best. If you want to know how logs are cut for best yield of clear lumber refer to my article on sawing logs in the Articles Section.
Re: What is Flitch?
Clint Searl
Example
Clint Searl
Flitch cutting a log has nothing to do with maximizing lumber yield and everything to do with maximizing the potential beauty that a log may possess. And the loss of a quarter inch, or so, between adjacent boards is irrelevant to the effect of book matching.
Here's an example of a desk by Ru Amagasu, Nakashima's grandson, featuring book matched flitch cut slabs of white ash.
Clint
Re: What is Flitch?
Lee Grindinger
American English
Lee Grindinger
Sgian, it's good to see you're still popping up from time to time. I hope all goes well for you.
It's fairly common on this side of the pond to use the term flitch for this style of sawn lumber. As with veneer the boards are sequentially preserved. The value to me comes not from matching patterns as you would in book-matching but from the ease in matching the various components for a single piece of furniture or grouping of pieces.
As I have I'm sure you're spent countless hours sorting through lumber piles/stacks looking for color, grain and texture to match lumber already selected.
Be well, my friend,
Lee
Re: What is Flitch?
Indeed
Re: What is Flitch?
Re: What is Flitch?
Fred Davis
Thanks Dan, it was none of the above, edit function is still gone , profile is the same .
FredD
Re: What is Flitch?
Lee Grindinger
Quite a challenge
Lee Grindinger
Sgian talks about the loss due to the kerf of the saw in addition to where in the log two matched pieces come from. I suspect in the desk pictured in Clint's post the priority was given to the figure closest to the viewer at the expense of the match concealed by the lamp.
Re: What is Flitch?
Fred:
Your profile user name is FredD. You can't use "Fred Davis" and retain your permissions. If you like, you can modify your profile to use your full name or whatever, but you can't interchange user names. These things are exact for a reason: to prevent spammers and bots from making a mess of our boards. If you don't delete your cookies, you will never have a problem, as long as you're using the same computer and the same browser. The cookies that remember your credentials are computer and browser specific.
Re: What is Flitch?
Re: Fred:
FredD
Thanks Ellis , that is what happened when about half of the time it wouldn't post without my filling in my name , like a dummy that's what I did , rather then use FredD.
Onward and upward
FredD
Re: What is Flitch?
Re: American English
Sgian Dubh
Hi Lee, perhaps the term flitch for through and throguh sawn is fairly common in the US, but I can't recall seeing it used here. I think of a flitch when describing a stack of veneers sequentially sliced. It's true that it can help a lot to get matches if you select all your wood from the same log, however it's cut.
Clint's example of the book matched table top rather counters my assertion that it's very hard to get a bookmatched panel out of through and through sawn wood, for it does show a book match using only two adjacent boards. It's fairly obvious that the match has lost quite a bit in the kerf, but it's still a very good, interesting and convincing match.
In Clint's example it helps to see the match because there are such strong features that you can read from one side of the join to the other, and there are only two wide boards used to make the match. I've seen similar matches where it's very hard to tell that the pieces are a mirror of each other. The reason for that were there were no stand-out distinctive features the eye could link between the two parts. I still say it is nearly impossible to join up say four, six or eight planks to make up a convincing sequential bookmatch as you can do with veneers; that was the point I was really trying to make in the first place, but I didn't say it clearly enough.
Oh, and yes, I do still visit and post from time to time. I don't post as much at woodworking forums as much as I used to-- I seem to be too busy, or perhaps I'm just not so commited to browsing and responding as I used to be. And I suppose I have developed a bit of a tendency to pass over topics I've seen aired many times, perhaps scores of times, before. Slainte.
Re: What is Flitch?
Barb Siddiqui
His Grandson! Quite a family.
Barb Siddiqui
