Part of router bit on an inside curve?
DouginDenver
When making small straight moldings I often use just part of a router bit profile and don't worry about the wood not contacting the guide bearing because the wood is guided by the router table fence. But now I want to put a small molding on the bottom of a curved apron with two inside curves, so the table fence will not work. I cannot for the life of me think of a way to use part of a profile on an inside curve because there is nothing to guide the wood, but just thought I'd ask. Those guide pins won't work because you still need the guide bearing.
Re: Part of router bit on an inside curve?
Don't Put Your Life On The Line
Instead, "temp glue" (with paper) a 1/4" thick piece to your molding made with the same inside curve, then raise your bit to put the bearing on that extra strip as a guide. Route and remove.
[maybe]
Keith Newton----Little Rock, Arkansas
I would use the router hand held. I cut a sub-base with the arc of the riding surface, taped to the base with carpet tape.
Then I add the other arc to the fence, or use a roller bearing or UHMW tip attached to the fence just over / under the cutter to follow a changing curves.
Re: NO!
Hal Smith
no, No, NO, NO!!! I assume you have all ten fingers and wish to keep them. I'd rather have not read this. I'm going to worry all day! I hope others will reinforce me. Hal
I agree
Lee Schierer McKean, PA
Unless you can remove the bearing and substitute a larger outside diameter bearing like is used in a rabbeting bit set, you'll need to attach a space to your skirt piece so that the bearing rides on it at the distance needed. Double sided tape or hot melt glue can be used for temporary attachments.
They also make a device called a pin router that will work if you can change the diameter of the pin.
Free handing the cut will not produce a smooth profile.
Lee
del schisler
you need to use the bering Don't deveate from this It is not safe Make a round templete of some kind for the bering to ride on I been using router's for yrs and if it look's like danger than it is Do it in a safe mode i count 10 here
Fred Davis
Mark has told you relatively safe way to accomplish the curve profile, what he didn't say was the grain can change direction in a curve and depending on how squirrely the grain pattern is , it could easily shatter the wood , making it a very dangerous operation.
FredD
