Hollow arch for Arbor
Bill Lordan, Auburn NH
I am building an arbor for my daughters 8th grade graduation. The teacher want it 7'x5'. I started by making 4"x4" holow column aand would like the same look to the arch. My idea is to cut 4 arches out of plywood, sandwich 2.5" spacers between and then wrap 1/8" masonite over the top and bottom. I will then paint everything white. This is for an indoor ceremony and the school may use it a few times a year. My question is: Is this method practicable or is their an easier or less expensive way to tackle this project. TIA for any help you might be able to offer.
Bill Lordan
Re: Hollow arch for Arbor
Sounds good
This is an exercise in set-building, and your solution sounds simple and workable. You might want to experiment with the hardboard to make sure it'll bend to the radii you're planning. You'll also have to figure out a good way to attach the masonite. Maybe a nail gun and some glue will do the trick.
Let us know how it turns out.
Ellis Walentine, Host
Re: Sounds good
Ellis is right, set building. And check on the bending of the Masonite. Not sure but I think the untempered type bends better than the tempered stuff. Locally, Home Depot carries 'door skins' which are 3' by 6'8" sheets of 1/8" plywood. That might work. Some plywood suppliers carry 1/8" plywood. (1/8" being a random term meaning 3mm or 3.2mm or something close) You might also find that cardboard (might be too tender) would work and you could use plastic laminate like Formica. If I used laminate, I would sand the face of it with about 80 grit to give the paint a little tooth.
Tempered vs. untempered masonite
Highly tempered masonite* is very stiff. The untempered stuff is more flexible, but not very strong. There's a mildly tempered stuff - what you'll probably find as "tempered" at your local big boxy store - that's a decent compromise. At least locally, the only place I can get the highly tempered masonite is the local contractor's lumberyard.
If this arch is high enough not to be bumped, the untempered stuff might be fine. I'd prime it with oil-base primer, though - water-base could make it puff up.
*"Masonite," by the way, is a trade name. It's kind of like "Kleenex" or "Sawzall," trade names that have become the generic names. "Hardboard" is the generic name, I believe.
Fred Davis
The Masonite will work regardless of the Tempering, what you need to know about it paint wise, do not use water base unless significant expansion won't be a problem. If you still want to use water base paint, spray both sides of the Masonite with water in a weed sprayer and let dry before you cut it up for assembly. This will prevent any further expansion.
Oil Base will not cause expansion.
FredD
Thank you gentlemen for your input. I'm glad to think that I'm on the right track in building this arch. I'll post info on how it all turns out.
Bill Lordan
