We value your privacy.
I would appreciate your sharing of your experience in installing heavy bandsaw such as the Grizzly g0514x2. The manual states that it should only be lifted with a forklift. Most woodworkers probably do not have a forklift. Even if I have access to a forklift, I do not have room for it to move around in my garage/workshop. So how do you get it off the shipping pallet and place in onto a mobile base?
You can rent material lifts and pallet jacks from your local rental yard. Material lists are, in essence, hand-cranked forklifts. You can also rent automotive motor lifts. Go to the rental yard, look at what they have to offer, and think about what will work best for you.
This kind of thing isn't hard if you know what you're about, but it can be scary as heck if you don't. Think a lot about what you'll do, evaluate how top-heavy the saw is (bandsaws and drill presses are both pretty top heavy), and don't do it if you're at all uneasy. At that point, it's time to see if you have a relative or neighbor who's experienced with this kind of thing, and see what would entice him/her to guide you through doing it.
You shouldn't do it alone in any case - you want at least one other person there who's physically competent enough to be helpful.
Seriously. I have an 18" Rikon which weighs a similar amount. I took the cast iron table out of the box. We ended up taking the bandsaw around the house to the basement. I figure if I could get down the slope - you could get it into the garage (with help of course).
I put two 3/4" bolts through the ceiling joists and with two come-alongs (how is this spelled?) hoisted it into the air over its base. As far as moving along the floor, two pieces of 3/4" pipe or 1" dowels under it and it will roll nicely on a hard surface. I see no reason that a strap around the top wheel housing would not lift it just fine. That is how I lifted my Delta 20' .
When my LT18 was delivered we took the motor and table off, removed the saw from the pallet and placed it on a hand dolly. Two of us had no problem at all getting it down the driveway and even tilting it to get it under a low door.
Agree with the pipes for moving on the floor. Use some help to get it on a mobile base. You can tilt it back and start bridging under the saw. Add a 2x4 under each side that is longer than the mobile base. Keep adding blocking under the 2x4's until it is higher than the base. Keep tipping the saw forward and back, adding that blocking. Slow but sure. Then reverse the whole process until the saw sets into the base. Don't add too thick of blocking at one time so the top heavy machine gets unstable.
We just finished moving a lot of machine shop equipment much heavier than that bandsaw (Grizzly's website lists it at 427 lbs). We ended up getting a shop crane (engine hoist) from Harbor Freight to move the stuff. But I'm sure you could probably rent one for the afternoon as well.
My wife and I handled a Grizzly 8" jointer, somewhere in the 400-600 lb range if I recall. A forklift was handy for putting it onto our truck (I live in range of a pick up!). Once home, I unboxed what I could on the truck. The motor is usually near a hundred pounds and often not installed. Take that out and your already a bunch lighter. Then I tilted the table out the back of the truck onto a dolly (laying on it's back). My wife slowly rolled it back and I picked it off the tailgate and gently set it down. Even at over 200 lbs (and I'm no animal or anything) it was no problem.
Definitely have help! Can't stress that enough. You don't want to be in the middle of a lift and need an extra hand. Use dollies, hoists, ramps, whatever works. You'll find that the best solutions are often the simplest. Sometimes having another 2 helpers is all it takes. Take the machine apart and reassemble it on the base if necessary - that way you'll know it's parts really well!
I had it in the back of my pick-up truck in a crate (fit by 1/2"!) and when I got it home, I had to unload it by myself. I backed the truck into the garage about half way, and then slid the crate to the tipping point, then stood it up. Parked the truck.
Uncrated it.
Tipped the saw to its side and installed the wheels. It's heavy, but manageable. I may have had my wife help me stand it back up, but only to keep it from rolling on me- no lifting.
but I uncreated it in the truck. The body of the saw and the top I lowered to the ground put it on a dolly and moved it around. When I put it on it's mobile base I laid it on it's side lifted the bottom onto the base then stood it up. The put the rest together.
