Re: Kreg Jig - Cheating or a perfectly good joint?
David Weaver
You're right about how long they last. Once they go in place, no problem. I did kick the side of one in once by accident when it was taken off the line and sitting on the ground, and I went to jog past it.
Ply was probably on the sides of 10% of the cabinets, the rest were particleboard, and these were considered mid-grade cabinets. Grooves were all cut in the particleboard by computer controlled machines (this was about 1996 or so). The particleboard is the really fine sawdusty stuff.
Some of the doors were cope and stick - the ones that weren't mitered and were of more expensive wood, like cherry and maple. Some had real wood center panels, and others not, but the doors were done so well that it wasn't that easy to tell which were fake center panels when you looked close. The finish was just a couple of coats of lacquer, but it was actually pretty good on the face frame and doors (sides with the particleboard, of course, had a sticker veneer/tape. Stain was applied evenly (the color thing again, people notice when color doesn't match) and there were some unfortunate folks there who did nothing but wipe stain for 40-70 hours a week (depending on how many hours they actually wanted). A novice finisher would do worse with the finish. I'm not sure I could actually do better even after finishing a few pieces - the finish was never uneven on anything there that I recall.
Nastiest style was called lakewood - apartment type cabinets.
I can't remember what the company changed its name to, and can't find much on google.
Drawer guides were those ultra cheap stamped painted guides held in with plastic dogs on the back. There was a person who did nothing all day but put cabinet backs into a site-made machine that drilled four holes at a time and had spacer jigs to get all of the holes for the guides in the right place. Another job on the actual assembly line was literally taking those guides, plugging the plastic ends on them and bending them (the guides) up in a jig and then putting them in the cabinets. That was hard on the hands - face frame edges are always sharp. That job was right after the units went on the line out of the clamps (pneumatic units that were like a jig and a clamp all in one to put the face frame, sides, backs and bottom together), too, and if you saw a loose brace in the cabinets, you had to be careful getting it out. The hot melt burns deep, and the people on the clamps had arms with deep burn scars all around their forearms and wrists -looked like they were in a swordfight without a sword.
I didn't mind it so much then, I wasn't a woodworker, and I was pretty proud of working on them and how good the face frames and doors looked, and all of the non-lakewood non-rtf doors did look pretty good - they knew what the customer wanted, and they made an effort to make that part look good. It paid decent for a college kid and you could get a lot of hours on the same schedule every day. It was well lit, well ventilated, and they were serious about safety and ergonomics.
Best job I had there was driving a box truck back and forth between buildings bringing doors back to the "door building" from the finish room. I'm guessing osha never measured the formaldehyde coming out of the truck when you got to the door building on a hot day, but it dissipated pretty quickly, and they did test the door building where the doors were and it was in spec.
Cost cutting got the factory last year or two years ago and it was closed and consolidated with another location. I always thought the people there probably had safe jobs because it was non-union, they weren't real high paid, and they were making something that would be expensive to ship.
