What size wheels roll well in your shop?
I have my lunchbox planer mounted on a base for a jointer and on wheels. (The jointer base was a yard sale find many years ago.) It occurs to me that if it were about two inches lower it would make a nice out feed table for the bandsaw when not in use as a planer. Thinking of building a cabinet to replace the jointer base and making it lower. I could park it beyond the bandsaw, out of the way and it would be also be useful in that position. I have swiveling casters on it now that are about 2 1/2" and they are OK, but they would be better if they were larger. My shop floor is not known for being spotless. It is rough concrete to start with and there might be a shaving or two from the lathe and a speck of sawdust. So, What do you recommend for wheels?
Re: What size wheels roll well in your shop?
Bruce, a MN Galoot
I have 2-1/2" ball bearing casters on my miter saw cabinet so I can move it out of the way in my way-too-small shop. Like yours, these are okay but that's it. Bigger would be better.
I have 2 1/2" casters on most of my rolling stuff for my shop.
At the theatre, I usually use 3- 4" casters for the smaller stuff and 5" casters for the larger rolling platforms (8'x8' or greater). Look at the weight capacity of the particular casters.
NickTuzzolino
To make things really EASY, I use no less than 4" wheels for any kind of cabinet mounted tool or heavy cabinets. Jointers and the like usually do better on the commercially bought steel stands with the smaller wheels that lock on one end.
All 2 1/2" Castors Are Not of Equal Ease and Quali
George Colonel's Workshop-Havertown PA
Good Afternoon Barry,
All my power tools are mounted on 2 1/2" wheels/castors. My floor is tiled and fairly flat. I find a considerable variation in ease of movement from one tool to another, and attribute that to the brand of castor, and construction. I replaced many of my original HF castors with others from different sources, including Woodcraft. HD, and JVC. Its still a mixed bag. Always a good thing to sweep the floor.
Somebody ought to test castors and determine the best size and brand.
George
And, of course, it's important to lubricate them
with castor oil.
Re: What size wheels roll well in your shop? *LINK*
Stephen Kirk
I have a lot of the 3" wheels from Woodcraft and they've worked well. They are expensive, but they don't get flat spots and don't easily hang up on debris or an unlevel floor. They're weight rating is fine for nearly all my tools.
Woodcraft casters
