OT Pressure Washer problem
Dustmaker Mike
Yes I am in Shanghai and I will not be home until next Saturday but I have a question. I have a Karcher 2400 PSI pressure washer with the Honda engine 6.5HP I think. The problem is when I squeeze the trigger sometimes the pump comes on sometimes it does not. If I let some water free flow without a tip on it then pull the trigger when I let go of the trigger the pumps comes up then stops as the water flow stops, when I put the tip back on, the pump comes on until I let go of the trigger then it will not come on again until I let the water free flow again. I hope somebody understands. Is this an air leak in the pump or a pump going bad or maybe a seal or gasket. I really don't think it is the engine but I was wrong once before(-;
I want to get this fixed when I get home so I can get on to other fun jobs this summer.
Re: OT Pressure Washer problem
Jason Roehl in Lafayette, IN
It sure sounds like the pump is on its last legs. What you described are pretty much the symptoms of a dying direct-drive pressure washer pump--the engine vibrations transmitted through the direct drive shaft shorten the pump's life tremendously. From what I've seen of them, they pretty much aren't serviceable, either (at least not for a reasonable cost in dollars or time).
Now, one remote possibility is that you have some sort of debris caught in the pump. Higher-end pressure washers come with all sorts of filters--a hose screen, sometimes a better one before the pump, and one on the oscillating tip, if so equipped. You could try running some detergent into it, or even squirting some WD40 into the pump while you pull the starter cord with the spark plug and all hoses disconnected.
Jason
del schisler
check the oil level in the pump may be low ??
How do I check the oil
Dustmaker Mike
Ok I am not at home so I looked up my unit on the Karcher website. They say to bring it in for service if the pump needs oil. So I am sitting here trying to figure out if it will be easy to add oil or I need to bring it in or just go to Northern Tools and get a new pump. I will trouble shoot when I get home I am just getting info up front to ake sure what I am getting into.
Thanks
Karcher
"Used to be" THE NAME is pressure washers, but then they went consumer-oriented with the 115v electrics selling everywhere, and stuff seemed to get pretty cheap.
You should be able to get a rebuild kit from Karcher, and the oil question (hydrolic NOT motor) should be answered in the manual [that you didn't read?].
That said, switch out the Karcher with a CAT pump; this is a bolt-on deal. You'll be happy.
Re: How do I check the oil
Most pressure washers I've seen have a small window on one side of the pump with a red dot in the center--indicating appropriate oil level with the pump not running. When it's running, you'll see oil flowing down the little window. And all of them that I've messed with the oil on took SAE 30 NON-detergent motor oil. That has pretty much only been to change the oil after the break-in period, something like 25 hours of use or so.
Jason
Wrong Oil
Oil goes in the engine should be SAE-30 non-det as Jason mentioned. I was thinking about pump oil as some washers require it, but in looking at Karcher's manuals, there is no mention of oil in the pump itself. Apparently there is no way to change lubrication on the pump shaft. Seems strange, but maybe that's why they want it "returned for service."
Yup I read the same thing
Dustmaker Mike
I was referring to the pump oil and how to check or change it. Seems Karcher does not want people in their pumps. When I get home I will take it apart and see what I can see.
I was too.
I'm not specifically knowledgeable about Karcher pumps, but on the pressure washers where I have changed the PUMP oil, it's been (by the manual) SAE 30 Non-Detergent.
So there's not even a sight glass on the side of the pump?
Jason
Jason I am not sure
Dustmaker Mike
I am in China and the washer is at home in the US. I get home Saturday night and will check it Sunday some time. Thanks for your help
Or
Maybe that's the WAY they get it "returned for service."
