Re: Questions for Dave Paine on Flatmaster
Dave Paine
Barry, I thought of the Sand Flea when I saw the Flat Master being demo'd at the WW show. I walked by, then picked up on "no heat" and walked back, then after the demo plonked down my money.
I did not stay for a Sand Flea demo in an earlier show, so I can only say that both units have the drum below the table.
I read your thread about making a table for the Performax and was tempted to do so.
In my Performax I have trouble keeping the piece parallel. In my case I somehow manage to get the piece thinner in the middle than the ends. I even made a sled to support the piece and carefully support on in feed and out feed, but somehow still get thinner in the middle.
The Flat Master uses hook and loop drum and paper. The demo talks about the paper being lifted by centrifugal force. This makes sense, since the hook and loops do have some give. The quieter operation likely results from just the paper being pushed against the piece by centrifugal force and not mechanical pressure as in the Performax.
The major difference in the Flat Master vs Performax is lack of heat when sanding. I can sand coatings without gumming up the paper.
The table top is not as deep as I would like, so I will be building deeper version. Since the user pushes the piece across the drum, it does need a consistent feed rate, although the small removal per pass means easy to remove in a subsequent pass.
The Flat Master produces very fine dust but the material in the drum does not create electrostatic, so the dust particles are easily vacuumed.
I have been able to achieve a flatter reference surface than with the Performax, and use my planer to get the piece parallel.
I also get much smaller lines in the piece. This may be due to using 100 and 220 grit, although I also have 320 and 400 to try later. In the Performax I use 80 grit since I found trying to use e.g., 120 grit resulted in burning of abrasive and then the wood. In my early attempts I managed to burn a piece on first use. I later changed to the Klingpor Zirconia abrasive, which is terrific and creates less heat, but not as little heat as the Flat Master.
I am using the Flat Master every time I am in the shop.
I mentioned the as-purchased fences were useless. I made one of my own which is dead on 90 deg and not can use Flat Master for edge sanding. Something you would try with your converted Performax. Edge sanding results were also impressive.
I hope this helps even though I have no real data on the Sand Flea.
