Naming Convention
Naming Convention
Naming Convention
Doug Reynolds
When "naming" a part on a piece of furniture, say the left side of a chest of drawers, is it the left as you look at the front of the chest or, the left if you were standing behind it looking toward the room? I've always named it as I look at the front of the piece but, that wouldn't work if I were making a chair because I would naturally call the left arm of the chair the piece my left arm rests upon.
What is the correct way, if there is one, so everyone understands what I am saying?
Re: Naming Convention
Yes
I'm accustomed to the exact nomenclature you described.
The chair makers of my acquaintance (and the way I was taught) is as you describe - which is to name it as you sit in it.
The only area of "controversy", so to speak, is in numbering the legs. The way I was taught was - with the bottom up and the front of the chair towards you - the front left leg is #1, the rear left leg is #2, the rear right leg is #3 and the front right leg is #4. If it has 6 legs - the middle front leg is #5 and the middle rear is #6.
Some prefer to "letter" the legs (A, B etc.). Others prefer to number them starting in a different position. As long as you are consistent, I suppose it really doesn't matter.
Moses Yoder
Moses Yoder
It is standard practice to call parts left or right as you are facing the piece of furniture. On a chair, the parts are normally symetrical so it does not matter as much which one you call left and which one you call right. I think chairs are an exception to the rule and you normally refer to left or right as you are sitting in the chair.
