Grizzly Baby Drum Sander - questions
Brian in SLO
I've been eyeing these baby drum sanders (G0459) for my home/garage shop and I see Grizzly has them on sale. I'm thinking about getting one but first I wanted to see if anyone else out there has used one and what good or bad there is about it.
What I like about it is:
Size - It has a small footprint and is about the same working width as my DeWalt planer. I mostly plan on using it for making boxes so it's a good size for my planned use.
Co-planar - I like that fact it has drum support on both sides vs the Performax that just hangs out there.
Price - Since Jet has taken over Performax the prices have risen to pay for the takeover.
www.grizzly.com/products/12-Baby-Drum-Sander/G0459
I appreciate any feedback anyone can offer.
Thanks,
Brian
Re: Grizzly Baby Drum Sander - questions
Re: Grizzly Baby Drum Sander - questions *LINK*
Dave Paine
I do not have a Grizzly Drum sander, but I do have a Performax 16/32 drum sander and it is now lying dormant due to purchasing a Flat Master.
I saw the Flat Master at a WW show in March. What caught my eye was the lack of heat when sanding.
Normal drum sanders create a lot of heat, and can easily cause build up on the abrasive. I have wasted many feet of abrasive due to burn build ups.
The Flat Master is like an upside down drum sander. The concept is the paper touches the piece not the drum. It really makes a HUGE difference.
I have successfully sanded off existing finishes without any problem.
I also am able to get a closer to flat result. Give this a look.
I got the 30in wide unit. I love being able to use 1/2 with one grit of paper and the other 1/2 with finer grit.
I would not get the fences. Big mistake for me. They are racked and not 90 deg, so useless for my work. Otherwise I use this unit a LOT.
http://www.stockroomsupply.com/Flat_Master.php
I have one
John b. SW chicago burbs
I have the baby drum sander it works as advertised. The sander does struggle a bit at 12" wide. I use the Klingspor 100Grit stearated sanding rolls, which are cost effective and work very well, and hand sand to get the required finish. I purchased mine when they first came out at the introductory price. For what you get i don't believe that i would pay more than the sale price. Overall i am happy with my machine. I have run cypress to oak and even a little amount of Ipe' through it. I do believe that a lot of the credit goes to the stearated paper.
As long as you do not expect production rates you will be happy with that drum sander.
john b.
I don't have one, but i do have a Performax 16/32. I can tell you that about ninety percent of what I sand would fit through a 12" wide unit. OTOH, when the wider piece come up, that extra capacity is REALLY nice.
As to being underpowered, I don't think the motor on mine is any larger than that. These units REQUIRE a VERY light touch. They are sanders, not abrasive planers. (A friend of mine has one of the big industrial 36" belt sanders and I believe he told me the motor is a 12hp 3 phase.) The depth control on my Performax has something like 1/4 turn equals 1/64". I took that to mean I could take a 1/64" at a pass. NOT! More like a 1/4 of that. But, if you are patient you can sand to almost perfectly consistent thickness and a nice surface. And It will handle wild grain that most planers would just tear up. Very useful for box builders.
