A cheap and effective wood "rasp"
Bill Tindall
One can pay jaw dropping prices for a good wood file/rasp, or you can make something equivalent for pennies. All one needs is illustrated in the picture. In summary, affix a strip of cloth backed "sand paper" to a flexible piece of wood (about 1/8-3/16" thick) and sand away.
I needed to sand the edges of some disks as show in the picture. This task is a good application for one of these "rasps". The rate of material removal with 100 grit abrasive is about what I would get with a fine rasp.
Abrasive: The abrasive choice is critical. It must be cloth backed "sanding belt grade" stuff to be durable enough for "rasping" applications. For example, using a typical paper backed sand paper I was able to sand about 2" of a disk's edge before the paper died. Using the product shown I sanded feet of edges and the abrasive was still cutting aggressively. If you are unfamiliar with J-flex become so, especially if you are a turner. It is an aluminum oxide abrasive bonded to a thin flexible cloth. Lasts "forever" and its suppleness enables it to conform to curved surfaces. It can be ordered from Klingspor Industrial catalog. Be sure to mention that your are a cabinet shop to get a substantial discount. Or go dumpster diving at the Klingspor store for $3@/pound.
Adhesive: I like the adhesive shown in the picture for fastening cloth backed abrasives to substrates for sanding. It sticks well and it is easy to use.
The stick: A piece of wood approximating a file, or even a file, make a good substrate for the abrasive. I prefer a thin strip of wood about an 1" wide but I have made blocks with curved surfaces up to 4" wide with a handle for serious abrading. .
