A couple simpler pieces
Alan Young
Alan Young
I am taking some smaller items to a small vendor show this weekend. I'll be exhibiting some new wall cross designs, breadboard/serving trays and these items below- A pair of Oak benches like the one in these photos and a pair of Shaker Step Stools in Ash
Even a Tall fellow can use a step-uip some times...
the camera broke after this shot :<)
-Alan
Re: A couple simpler pieces
Well Done and
a question.
You ever have a Bill Ding set when you were a kid? ;)
Re: Well Done and
Ron in Sterling, CT
It's better that the camera broke, than the stepstool!!
paul in AZ
Nice!
You should do well with the library step stools.
I've made several of them in white oak or cherry with dovetail joinery throughout. Dovetails on the steps are an eye catcher. They are popular and very useful.
For the next batch -if there is one- consider cutting in an elongated slot ~ 1x4" into the top step for a hand hold. Makes 'em easier to carry around.
Variations
Also consider a tall handle (ala Esherick) to make older types feel more secure.
Fred Davis
Great looking step stools , hard to get a new look for those that hasn't been done, but you did , very nice , hope my wife doesn't see them before next Winter
FredD
joinery questions
Bill Tindall
Stool: How are stretchers fastened to sides, steps to "stringers". and the triangular insert to the stringer/step?
I like the stool. Bench is a bit too angular for my taste. A bit of rounding here and there would more appeal to my strange taste.
Alan Young
Re: Well Done and
Alan Young
Can you believe I had to google that question? Never heard of it!.
So no I did not have a Bilding Set as a kid. But watching my dad and grandpa was a Building experience.
-Alan
Alan Young
Slots,Handles, Dovetails ect
Alan Young
Very good thoughts about the variations available for these somewhat common little stools. These were a quick build as I needed something for this weekend-It's not a big event but I wanted some variety in the things I am displaying. I'd rather keep these two little Shaker stools as they are made from an Ash tree from my home in ND. I hope to make more of these pieces and will probably incorporate those features in subsequent efforts. I used dowels for joinery here.
-Bill -The bench is bit on the angular side. I think it's basic form has some room for experimentation...-Alan
Warren White
I really like the step stools! I too am interested in the details of the joinery and would also like to know about the finish.
I agree about keeping them, especially in view of the personal nature of the wood.
Very, very nice! Thank you for sharing your skill on such a useful set of projects.
Warren
Alan Young
Non Fancy joinery
Alan Young
Glue and dowels were used here. As has been mentioned in other posts-dovetails would add to the look of the pieces and probably the joinery strength-although I'm not concerned with these as they are. Because the grain of the steps and the sides run in the same direction-I glued the steps along the "aprons" and the sides. These are simple in overall design- I searched around the web for shaker step stools. After seeing a few I drew this basic design-18" high and wide and 9" deep for each step.
That is the larger of the two that I made.
I added the diagonal braces just for a bit a flair-how much flair can a Shaker Stool accept? :^)
My wife saw the first and said the rise needed to be less.. so the second ie smaller one is 18" wide and 7" deep and high. This smaller one is a great exercise stool. You can get a decent aerobic work-out just by stepping up and down through a cycle of your choice..Michigan winter's being what they are this could prove to be a cheap winter walking devise-
The larger stool has Non waxed shellac ie Sealcoat finish. The smaller one has a Tung Oil Varnish- You can see that gives it just a bit more depth of color. (The reddish hues on the lower step are from the lights in the room)
-Alan
Re: Well Done and
George Colonel's Workshop-Havertown PA
Good Evening Allan,
I had a Bill Ding set and it bore a striking resemblance to you :b
George
They are beautiful
Very nice work, Alan. The only thing that is missing is something to reinforce that short grain on the side panels. It's always been part of this particular design problem, probably starting long before the Shakers came along. Sometimes the Shakers dealt with it, but not always. To an extent, it depends on the species of the wood and how strong it is along the long dimension.
If you engineer this piece thoroughly, you might end up putting a cross piece across the side panels/stringers, under the lower step and extending to the back, with slotted screw holes to allow for expansion/contraction. If you don't need it, great, but be aware of this weak point in the design. You can also reduce the risk by using a shallower radius in the bottom cutout. This gives you additional length to the vertical seam.
Good Evening Allan,
I sure like them all. The stools are charming. The seal coat finish may not "stand"up to constant use, but then its an easy repair. I've looked for suitable benches to build for our Dining Room, always with as mind to incorporate a low back on each, and upholstered seats. Haven't found a design yet to use. Yours go well as intended, and by their looks, will provide steady seating for generations. Nice jobs.
George
Actually
the legs and foot pads on Alan's bench are very evocative of the Bill Ding figure.
The toy was a fascinating exercise in spacial relationships, balance, and the use of repetition of forms as a design exercise. I actually used a set of them in my high school sculpture class to teach those concepts.
Alan Young
OK-That has been nagging me...
Alan Young
Been wondering how much to be concerned with that issue. I guess it isn't too late to add a piece such as you suggest- I'm wondering if I ran a dado in the joint between the two sections and glued in a spline if that would be sufficient.
-Alan
Alan Young
Thanks George
Alan Young
Not sure what I was thinking when I put the Sealcoat finish on that first one. You are right that it isn't the "sturdiest" finish for this application. I guess it can take a varnish on top...
-Alan
Alan Young
ha ha!  My Dad always called me
Alan Young
Henry-because as a young lad I resembled this cartoon character :^)
Re: OK-That has been nagging me...
Your wife and Ellis have hit on the two things my little voice was complaining about. Nine inches is too high for a step. As a builder (of houses) I studied the design of stairs. 7 x 10 was considered Ideal. (I know there are a billion variations and a set of loose rules that govern them, but 7 x 10 is a good starting place.) So, shortening the rise to 7 or 7 1/2 was a good idea. 9 x 9 would make the stool considerable my "tippy" also. I would probably in the appearance and vastly complicated eh design and construction, but it would be "better" if the base were flared out so that the foot print were as large as or larger than the top. (We had a stool my MIL brought back from a craft vendor at Dollywood. The top projected about two inches beyond the base all the way around. It was a neck breaker. When she wasn't looking, I rebuilt it. She commented that the stool wasn't as bad after you got used to it.)
And, I agree with Ellis on the short vertical grain. That was my first impulse when I looked at it. I don't think your spline idea will add much strength. You are just moving the problem slight to the front and rear. The ash is not much longer at that point and adding the spline may actually weaken the ash.
If you make more, since the ends are nearly square, how about rotating the pieces ninety degrees and running the grain horizontally?
Mike Rubes, Apex, NC
Hi Alan,
I like these a lot. I love the simplicity of the Shaker design. They work very well. I like the angular bench. The angles and contrasting woods appeal to me.
Thanks for the pics.
Mike
Needing a few more hours in the day in Apex, NC!
Typically...
... Shaker stools had front-to-back cleats on the insides of both sides, under the lower step, to reinforce the sides, **unless** the sides didn't have any cutouts at the bottom. The cleats were typically screwed on.
The ideal staircase tread height of 7" - 7 1/2" wasn't taken as gospel when making step stools. In fact, it wasn't unusual for Shaker step stools to have step heights of 10". Most of the examples I've looked at are between 8 1/2" and 10". But there is a center-of-gravity issue here, too. Some Shaker step stools had sides that sloped back, to center the top tread a bit and reduce the risk of tipping.
Alan Young
Thanks Ellis
Alan Young
As you know I am quite fond of re-inventing the wheel. That cross piece could be added discreetly to my pieces..
-Alan
BTW I found this on Pop Woodworking site...
The weight is not distributed over all the short grain-I'd guess at best the weight of the lowest person and 1/2 of the second person is stressing the short grain on the low step. The upper step seems to have a relatively long grain joint...
Remind me to...
.... bring this up with the PopWood guys. :)
Actually, I recall I've already had this discussion with them in the past. Keep in mind that the strength of that short grain is species-dependent. Softwoods and straight-grained pieces will not have the same resistance to shearing force as denser hardwoods and species with interlocked grain. Add to that the length of the short grain. All I can say is that the Shakers didn't trust it without cleats unless the short grain wasn't that short.
By the way, anyone could stage that photo. If you did a vector analysis of the forces on a piece like that, though, you would most certainly not offer this as proof that you can flout shortgrain construction limitations. At some point, a heavier person or a sudden force will tip the scales and the stool will come tumbling down. This is the laddermaker's conundrum, and it's also why laddermakers pay such high liability insurance premiums.
