Drilling in end of 36" piece
tom rex
I have a 14" floor drill press.
How would you recommend drilling a 3/8" hole 2" deep into a 36" long piece of wood for a dowel rod?
T Rex
tom rex
T Rex
Re: Drilling in end of 36" piece
Keith Newton----Little Rock, Arkansas
Tom, Rather than trying to put the 36" long piece on the drill-press, I would suggest that you cut a 2" thick piece of scrap, that you then drill with the DP, to get centered. Then use it as a drill guide for hand drilling by clamping it onto the end of the long piece.
Phil Joines Krum,Texas
If there's room under the quill for the stock, there is on my Delta, take two pieces of scrap 3/4 ply or mdf and glue and screw them together at 90 degrees. Take another piece and make a reinforcing block. Drill a couple of 3/8 holes in tone side and bolt it to the DP table with the vertical edge extending just past the edge of the table. Put a long piece of drill rod or other strait, round stock in the chuck and use it to draw a line on the jig. Now you have a vertical drilling jig. The line if a reference to get a strait hole.
Re: Use your TS tenon jig
brian in brighton
I had to do the same thing. Mount your tenonning jog on the press table with the stock hanging down to the floor. Now swivel the quill over the center of the stock. Clamp the stock using the handy dandy stock clamp with fence on the jig. Put the bit in and drill to you hearts content.
This is the idea I sent in to FWW 2 years ago and it was shot down!! I've never seen it in a single book or magazine, yet they shot it down. Now Wood and FWW just seem to print the same old lame ideas, some are new, but too many are recycled.
Brian in Brighton
Assuming you want the hole straight and centered, you need to do two things: You need a bushing to guide the bit straight and you need a centering arrangement. In this case, the design problem also calls for quick, cheap and easy, if I'm not mistaken. (If you're making hundreds of these widgets, the plot thickens.)
Building on Keith's idea, I'd square up a chunk of scrap hardwood, maybe a 2x2 about 3" long. Clamp it to your drill press table, and center the hole in the table under the bit. Drill a hole the diameter of your dowel into one end, about halfway through the block. Then, drill the rest of the way through with the bit you plan to use for the hole in the dowel. Now you can clamp the dowel in your vise, slide the guide block onto it, and use it as your drill bushing. The hole will be straight and centered.
This is a good way to drill handles for turning tools, too.
pecker
Tilt the table to 90 degrees, clamp your stock to it, and make sure it's in the same plane as the bit, using a level or straightedge.
You guys are amazing.
Tom Rex in TX
So many good suggestions.
Thank you very much,
T Rex
Not Done Yet
A self-centering doweling jig with a long 3/8" brad point bit in a hand drill will do quite nicely for this.
Re: Not Done Yet
John Pappas
I believe a standard drill bit will work better on end grain than a brad point bit which will tend to follow the grain.
