We value your privacy.
I apply oil "wiping" stain with a pad instead of spraying or using a brush. The advantages are more control of the color development and less stain wasted. All the excess stain wiped off from 4 doors is contained in the rag in this picture-not much wasted.
A pad is made from a wadded up piece of cloth that is then wrapped with a second piece of cloth and then "tied" with a twistie. The pad is *lightly* dipped in the stain and transfer to the wood is made by rubbing, much like padding shellac. More pressure releases more stain, less rubbing releases less stain and thereby the color development is controlled.
I stain about everything I make with oil based wiping stain.
I used those foam brush thingies 'till I got tiered of them disintigrating in the middle of a run ( HATE those blasted "crumbs" ! ). Switched to (excuse my Norm-ism) cotton waste in the form of rags. More control, MUCHO less waste and, I feel, better penetration. I'll have to try the extra rag in the middle though.
I use the technique with varnish and shellac. It works very well for me.
In the last five years, I've found myself using very little oil stain, though. Can't tell you why, really, unless it was just frustration with the yellow cans. Now, some gel stain now and then, typically Olympic, because that's what someone gave me, goes a long way. And uses the same techniques.
Good job with the pictures. Don't forget the nitrile gloves.
Great idea for small to medium work. For big work like shelving unit backs, I like to use a pad painter. The foam backer holds the stain like your ball, but the wide applicator lets you fly across the plywood.
Kind of a "Doh!" moment for me. I have used that technique for applying shellac for ages. I was wondering the other day how I might apply a glaze to light parts of some wood and feather it out in the darker sections. Now I think I know!
Bill, I've tried your method in the past and find that it works best on diffuse-porous and tight-grained wood. I've had less satisfactory results with ring-porous and large grained species, especially if the pad is fairly dry as you suggest, because the stain doesn't get into the pores.
Now, you've got me thinking about how to use your method to advantage. First, let me say that I rarely use oil-based stain alone, primarily because it soaks into the earlywood but gets wiped off the latewood, resulting in a contrasty grain appearance. For this reason, I usually prefer dye stains on open-pored woods if I'm looking for a uniform appearance. But, I often pre-stain with dye -- sometimes of quite a different color, depending on what I'm trying to achieve -- and then follow up with oil-based pigment stain to add richness and depth to the dyed wood. It occurs to me that your padding method would be perfect for those occasions when you want to use the two-stain process but you don't want to get too much of the pigment down into the growth rings. Padding it on would tend to keep it on the surface, thereby reducing the contrast while still adding the richness of the oil/pigment stain.
I'm going to have to try this out. Anyhow, thanks for the suggestions.
I use the technique for walnut all the time wit a moderately damp pad. For oak the pad needs to be very wet to penetrate the large pores. Some sheep wool inside is beneficial for these occasions.
