OT computer problem
OT computer problem
OT computer problem
james runchey
When I connect to the garden web forum it comes in very tiny, covers only about 1/4 to 1/3of the screen with type so small I can barely make it out. This is the only website that does this. How can I get it back to normal? It's fine on my desktop comp, full size. This is on my laptop with windows 7.
Re: OT computer problem
Tim Caley
What is different between your laptop and desktop? Are you using the same browser? The same operating system?
james runchey
They are both running firefox, the laptop is windows 7 and the desktop is XP.
Galen Vetterick
Look at the Zoom level under View or maybe in your lower right hand corner of the window. Probably set at smaller than 100%
Use CTRL +
Dustmaker Mike
go to the page and select "CTRL""+" form your keyboard this should bring it to a larger size font. Get it where you want it then go to another website and see if it is the same as before. Go back to the one that was small and see if it stayed big. If it did you are done if not then you may need to clear your cookies then reselect the site.
Good Luck have fun.
Re: Use CTRL +
james runchey
Worked like a charm, Mike. Thanks much.
