According to my local expert...
Grant in Iowa
I have a professional woodworker friend and member of our local woodworking club who just gave the club a presentation on his Waterlox finishing method.
He sands to 150+ grit, and perhaps more on dense woods like tropicals. He also sands end grain to a finer grit most times too. This prevents the end grain from being a lot darker.
Then he does a coat of Waterlox for its beauty and ability to bring out the grain features in the workpiece. Within a few hours, he inspects the surface to ensure that there are no sanding marks. If there are, he sands them out by hand and applies another coat of Waterlox, wiping away the excess. Then after it dries again, he applies a LIGHT coat of Minwax wipe on poly in either satin or flat finish. He applies it with a foam brush and then wipes off the excess with a blue disposable shop rag(Sams club) immediately. This seems wasteful, and like you might not be getting anywhere, but the wipe-off is necessary. Waiting until the surface isn't tacky again, he applies a second coat of Minwax wipe on. I think he sands with the grain with an abralon pad between coats as necessary to remove any nibs. You could also use 0000 steel wool, so long as you clean carefully afterwards.
He claims that in one long day he can take a project from ready to finish to done, getting 4-5 coats of wipe on poly over the Waterlox. He can even work on other projects at the same time in the same space, since it is only tacky for maybe 20 minutes before it hardens to where dust isn't an issue. This assumes the humidity cooperates.
Waterlox is a good product, but in the presence of alcohol or similar liquids, the wipe on poly can provide superior protection. Part of my friends presentation was that the above process is what he uses for any horizontal surface. He says he does use only waterlox on some items that will not be handled or abused such as wall hangings. You can also do several coats of waterlox and then do one coat of Poly if you desire, but I like his one coat of Waterlox approach and see little reason to make changes to his regimen.
I have been nothing but impressed with the finishes he achieves with this regimen...and fast. Further, a wipe on poly finish can easily be repaired in the future by adding more finish layers. Even sanding back to bare wood and starting over can be done with the Waterlox/ poly combo.
It should be stressed that he is removing nearly all of the Wipe on poly by wiping after each coat. This is the secret to a quick drying smooth surface, he says. On larger pieces, you may need to do it in sections so it doesn't get tacky before you wipe it off. Further, he says the Minwax product works well for this, and he doesn't recommend substituting other brands, as he hasn't had the best results with them.
He builds high end custom projects and artpieces aimed at upscale buyers for a living. The finishes on them are very nice, he has total control of when to stop the poly coats so you don't get a plastic look. He usually stops at 4-5 coats on oak, so the grain texture is still visible in the rings of the wood.
Anyway, that is what he does, and I highly recommend that approach having been impressed with the results.
FWIW,
Grant in Iowa
