REAL MILK PAINT
Sliding Garage Door ...
Joe Burke
I've got to build a sliding door into my shop. App. 5' x 8'. It's just easiest to call it a garage door.
I've researched lumber choices and I'm familiar with most of the usual suspects, but I thought I'd garner some opinions from here as to what species might fit the bill for this job. As I said, it's a slider that'll hang inside. One side to the elements and one inside ... how else could it work? I'd bet sun exposure is as much a concern as rain. I'd figured I'd paint the outside ... maybe the inside too ... or poly the inside while painting the outside.
I'd bought some cypress from a local yard a while back for this job, but the 8/4 was green and just wasn't meant to be. I have 3/4" T&G cypress that'll work well for the panels, but I'm still undecided about the frames. I'm not opposed to painting it all. Function first and foremost.
Fire away ...
Re: Sliding Garage Door ...
My two cents...
... is that it doesn't really matter. You plan to paint the outside of the door, and it will be hanging above the ground, so any species should be fine.
Re: My two cents...
Joe Burke
I'd wondered about that very thing. Thanks for the affirmation.
I'll still take any other suggestions though ... about any aspect of this little project.
woodenleg
The last door that I built, I used 2x2 for frame and used strafoam(?) for insulation. I used plywood for both sides and added 1x to make it look the way wife wanted. I have a L shaped hook to hold it tight ( so the wind cant move it or dogs ). I then put dry erase board on the inside along with my posters telling me want size drill bits or nails ( I home school some local kids on making different things ). I also nailed some fire hose to the bottom to help keep wind and weather out. I lube the rollers twice a year spring and fall with WD 40 and spray silcone. Good Luck Dave
Re: My two cents...
Be careful with the design of the bottom rail. If the top of the lower rail is flat/horizontal and rain regularly hits it, the groove holding the panel will fill with water and cause it to rot. Hopefully it will be in a rain shadow.
Re: My two cents...
Joe Burke
I'd actually thought of that. That any horizontal groove might fill up with water and be problematic. I'll have to ponder that a bit.
I'd prefer to be "cheap". How about a "frame and panel" door? You can get any reasonable exterior grade plywood or barn paneling for the panel part and use "woodenlegs" idea of a dry erase board for the inside part of the panel (plain white shower panel 4 x 8 sheet - available in the big box stores). Use a suitable 2 x 8 for the frame.
I like dry erase boards - I can rough sketch an idea out and see if it works.
Re: My two cents...
Make the weather side of the door vertical boards and the inside cross bucked with diagonal bracing. Rip a bevel on the bottom of the door that slopes down toward the outside, creating a drip edge.
Dale Lenz
Dale Lenz
I'd consider hanging the door on the outside, most barns do it that way. It would be easier to keep rain out of the shop with the door hung outside, thought for chewing on. I've heard the barn doors have some sort of a contraption that will suck the door tight when you close it.
John Veerkamp, Western Mo
One other consideration, if door will have snow pile up on the bottom rail, be sure to use rot resistant wood. If you have no overhang, you will either need a waterproof railcap, or hang the door on the inside. Barn doors are done both ways. Better tracks have a small offset at the end so that when they are fully closed they suck up to the wall.
why a sliding door.
Bill Tindall
I would want a door to a shop that sealed, ie a hinged door, presuming the rest of the shop is sealed. What will be going through this door that won't fit through a standard exterior door 36 or 42" width?
Re: why a sliding door.
Maybe a truck.
Wish I had a shop I could back into (without going through a wall, that is.)
John E in SC
How about French doors? I have exterior french doors in my basement. One side stays closed with sliding bolts top and bottom, and the other works like a regular door, but by opening the bolts, can open both doors all the way. Seals very well.
added benefit
Bill Tindall
Natural Light. Shops can't have enough of it. I can't think of anything that would need to pass that wouldn't go through a standard exterior door, but the French Doors will add lots of daylight. I work in a "cave" and would love to have the light available from French Doors.
Gary Smyth
I�d seriously reconsider the sliding door. I didn�t come to this on my own, but through a friend of an ancient friend who worked on the New Yankee Workshop staff (Bill?). At any rate what I heard was that the second icon of that show (after the sign) the sliding door, was a mistake. They were looking to build in colonial style (check the bottom clapboards) so they went for the saltbox "barn" but it was a sacrifice. The door took up too much space for a shop of 900 sq ft. It had to be offset at a corner or it would have limited cabinetry on not just one but two corner walls. When opened it blocked what were to be windows. When closed only the mini clerestory windows in the door provided any light. They built a workstation on the �sliding� wall instead and lighted the hell out of it for television. Light was not a problem on that show, they could almost heat by lights alone, but the wind was, and in addition nothing could be permanently placed near that door. To give up what amounted to 64 sq.ft. on that restricted space was an error. Now if you have the interior space and are willing to put most stuff you need on wheels, it�s a start. On the other hand if you need to heat the space and need the space I�d look for other alternatives. Maybe a wide Dutch door or double Dutch doors. At least they can be made to look old, will admit light, (but also bugs) and they seal tightly. I�d look to horse barns as many today are perfectly suited to variable temps and I think that the hardware is cool.
