Production Glue Up
Production Glue Up
Production Glue Up
Doug Reynolds
I need to glue up about 40 panels of poplar 1/4" thick by 11 inches wide and 15 inches long. The width was too much for me to resaw on the bandsaw, so I resawed to about 3/8" strong and now need to glue. Any ideas on how I can make this go pretty fast? I was going to leave them thick off the bandsaw, glue and then plane to final thickness. As of now, the two pieces of poplar are not the same width so, I am picking and choosing two pieces to end up with the width I need.
Re: Production Glue Up
Spring jig
Here's an old instrument maker's trick for gluing up thin panels: Screw and/or glue parallel strips of wood to a piece of junk plywood. The strips should be just a tad closer together than the combined width of your panel. Put glue on the mating edges of two panel halves, lean the mating edges against each other and press down to apply pressure to the joint. use a mallet or block to make sure the pieces are in the same plane.
If you run several rows of these parallel strips on a sheet of plywood, you should be able to glue up all 40 in two batches, without clamps!
Cheers,
glue 31" lengths
Bill Tindall
With yellow glue the panels only need to be in the clamps about 1 hour so in a 9 hour day you could make half the parts you need.
Keeping 3/8 panels from bowing in the clamps will be difficult.
Spring jig variation
Jesse Cloud
Another way to do the spring jig, particularly if not all your pieces are the same width, is to have the two parallel fences a little larger than the combined width of the panel and apply two wedges snugged into each other every few inches. Place some weight on a piece of waxed paper on top of the glue up to keep it flat.
I use this option to edge join veneers. Works like a champ.
