Delta 2 speed Shaper - question
Joe in a Cleveland suburb
Hello.
My dad gave me his rarely used subject shaper over the weekend. It's like brand new. Not sure I'll ever use it, but it was free so what the heck.
It was a little bit of a challenge getting it into my basement. It's pretty heavy. I was able to remove the base to make it a little easier but the top and motor are heavy. A dolly, my son, and wife helped.
My dad only ever bought a couple cutters to use. He just never really used the thing so never had a need for many cutters.
My question is, is there a way to use router bits on these things?
Thanks.
Re: Delta 2 speed Shaper - question
I have a small Delta Rockwell shaper about forty years old. It came with a short shaft that allows cutters to mounted right on the end of the shaft. I don'thank you can drop the shaft far enough to allow for a chuck for the router bits. Mine only turns about ten thousand RPMs. Pretty fast, but slow for a router unless you have really big cutters.
Larry
Delta and others make a shaft that fits the shaper to hold the router bits. I had one.
Larry
Here's what it looks like, http://www.toolorbit.com/Delta/Delta-43-824.html
Alan in Little Washington (NC)
A couple of things to think about.
First, Delta and a few other vendors made/make router collets that fit Delta shapers using the existing or supplied draw bar.
Delta changed the design of taper on their shapers sometime over the years, so make sure the router collet you order fits your exact model. They are NOT interchangeable.
The price of one from Delta and others can be a bit high, as much as $200-$300.
Richard Andrews who hangs out over on OWWM sells a Grizzly shaper router collet that he machines to fit Delta shapers, all for $75. He does a superb job and it fits my Delta perfectly. It has a 1/2" collet and comes with a 1/4" reducer for those bits. His web site is: http://artisans.homeunix.com:443/product_info.php?cPath=26&products_id=154
Thanks for the info.
