200+ woodworking book reviews
Spar Varnish - Drying Time?
David Lykins - guitardude - Dallas GA
Well, I'm actually back in my wood working shop, I just finished building a stand to place my RC plane fuselage and wings on for building and repair purposes. The stand is made from standard 1/2" Birched faced plywood. Anyway, I had some Bear "Spar Varnish" ( satin finish) probably at least 10 years old or so, seem to mix up well and applications was good. However, the peices have been sitting in my basement at least 48 hours and they still feel a tad tacky. I've never used Spar Varnish before so I don't know if this is normal for Spar Varnish or mine is just old and I shouldn't have used it? I'm wondering if I may have too much humidity in my basement, I'm really not sure what the humidity is down there. However, a week or so ago I made a bottom drawer for my bird's cage, painted it with Latex, and it seem to dry within a day.
Today its sunny here in GA should be around mid to high 80s, so I set all the peices outside to see if I could get the darn things to dry, hopefully that will work.
Again, any info' is greatly apprecatied.
Thanks!
Re: Spar Varnish - Drying Time?
Howard Acheson
If it won't dry, it means that the finish is no good. Oil based finishes have a shelf life of about a year if they have been opened. The test is seeing if it will dry.
At this point, you are going to have to remove the un-dried finish. The best and fastest way to do that is to use a chemical paint stripper containing methylene chloride. Follow the directions on the label.
For the future, in the overall cost of the project, the finish is one of the least cost components. It's not a place to try to save money. Use good and fresh finish.
Too Old
David Yoho
David, as Howard suggested, your finish is probably too old and will not dry like it should. Given the age you said, it's beyond using. Try removing and going with fresh finish.
David
I'll place a bet that it will dry quickly at 80 de
Bill Tindall
I have 25 year old varnish that dries just fine if the temperature and humidity are optimum. Spar varnish is a soft varnish anyway so it needs to have optimum time to dry to feel hard. When cool and damp I have had it take 3 days to harden up, where as it takes a few hours at 85 degres.
I concur that it may be too old.
Even with fresh spar varnish, though, I've found it takes up to three weeks in my climate to get hard enough to rub out.
Hi guys, thanks a bunch for the tips and info'. I just stepped outside about 20mins. ago and its actually seems to be drying now. But I WAS VERY scepticle that it would dry well because I really don't know how old this varnish is.
We'll see how dry it gets today and I'll let you know.
Thanks again, guess I'll use my shellac I mixed up next time...:^)
I agree...
John in NM
I've had varnish take longer to dry even when it was hot and humid. Warm to hot and dry is optimal, sometimes it'll even dry too fast.
Ed Henderson
I have used old spar varnish with good results but on important projects I go down and buy a new can. If you decide to remove the old stuff, here's a trick to try before you do that drastic messy step. On many occasions when it appears to be drying very slow, which can also be the result of not mixing thoroughly, I have got my heat gun out and heated up the finish. This has worked consistently for me, even when I rush the job and don't want to wait the prescribed time before applying a second coat.
If you did not mix properly, this may not work.
But on your project, I would have bought a new can.
Ed
Jesper, Denmark
Jesper, Denmark
Normally in "normal" conditions spar varnish takes 24 hours to dry enough so that you can sand and put on another coat.
High humidity and thick coats are problems. The spar varnish will skin over and not let the stuff underneath dry. Heat and sunlight (UV) helps.
...and try to stay away from Methylene Chloride if you can - carcinogen and a very small molecule, which easily enters your body through the skin.
