OT another computer problem
Jim Runchey
Got new cellphones from US Cellular and we signed up for cellphone internet service. They gave us a modem to hook up thru the USB port. I hooked this into the laptop and I can't believe how much faster this is over the old Wild Blue satellite. Anyhow the salesman told me I could hook this modem into the wireless router to furnish access to both computers. My problem is I'm not sure what the router is. There's a little box on top of the desktop about the size of a pack of cigarettes with a little antenna on top and there is a black box with four green lites on it over where the wires come in from the dish. Neither one has a USB port that I can see. Do I need a new router?
Re: OT another computer problem
Dan Donaldson
Where does the wire from the laptop usb port connect on the other end?
Dave Paine
The box with the 4 lights is either a router or a network hub.
A router provides IP address's to allow equipment to connect to the internet.
A network hub allows equipment to be connected to a local house network, but will not provide IP address so the equipment cannot connect to the internet from a hub.
The box with the antenna is a wireless adapter. This may be connected to the 4 light box via a network cable. It could also provide the wireless router service in your home.
You will either need a USB to ethernet adapter or a new router. First you will need to determine which of the two boxes is providing your IP address, since this will be the one which would need to be connected to the USB modem, or replaced.
If the wireless box allows a network cable connection, Try connecting a PC to this box with a network cable. If you then remove the power from the box with the 4 lights and can still get to the internet, then the wireless box is the router.
Difficult to cover all potential test scenario's without knowing exactly what connects to what in your system.
Grant Wilkinson
Jim
You don't need a new router. It will not have a USB port. It will have ethernet jacks in it. There will be one for each pc you have on your network and one to go from the router to the modem. It is usually labelled WAN. You will use an ethernet cable to join the modem to the router. The ends look like a large version of the clip ends on a telephone cable.
Grant Wilkinson
Sorry, Jim. Between the time that I saw your message and when I posed my reply, I didn't refresh and didn't see that you already had replies.
My D-link router has a usb port.
Dan Donaldson
Re: My D-link router has a usb port.
Grant Wilkinson
I stand corrected. I forgot about Shareport connectors.
