Powermatic 66
Powermatic 66
Powermatic 66
Doug Reynolds in Seattle
The blade on my Powermatic 66 suddenly came loose after a lot of ripping. Luckily it did not come flying off. When I tried to tighten the arbor nut tight to the blade, the arbor seemed to continue to turn and not allow the nut to tighten. I've had the saw since 1997 and believe I know how to mount a blade. This has never happened before but, the arbor set screw has come loose allowing the blade to wobble. I tightened the blade as best I could and tried to see if I could move the blade side-to-side as if the arbor set screw had come loose but, it does not move side-to-side.
Any ideas on what to check as I am dead in the water?
Re: Powermatic 66
Re: Powermatic 66
Fred Davis
Doug,
call 800-274-6846
7:30am to 5:00 pm (CST)
Monday to Friday
Have had this PM 66 for about two years less then yours , never had a problem with the arbor or heard of one like yours.
You should fix the the problem for sure before you use the saw.
FredD
Re: Powermatic 66
Re: Powermatic 66
Keith Newton----Little Rock, Arkansas
Does this saw have brakes that stop the rotation when it is turned off?
All saws are set up to turn in the direction which would tighten the nut while in use, so there should not be much worry about the blade coming off during use. However having a brake that stops the arbor quickly may cause the inertia of the blade to spin the nut loose when the motor is turned off.
Re: Powermatic 66
Re: Powermatic 66
Keith: No, it has no break. And, the nut came loose after quite a bit of ripping. It's a wonder the blade didn't come flying off.
Re: Powermatic 66
Re: Powermatic 66
Bob Lemon
Did you put the washer back on the arbor after you put the blade on??
Re: Powermatic 66
Re: Powermatic 66
Bob: Yes I did. I found an entry from 2005 on Saw Mill Creek stating, "There is an Allen screw in the very top of the kingpin that holds the arbor assembly and bearings in position...If it does come loose it will cause wierd problems (arbor nut coming loose with zero clearance inserts). I was using a zero clearance insert today when the nut came loose and, I did have a set screw come loose a few years ago which caused the blade to move to the left and right slightly. It took me some time to figure out why the cuts were not straight and why the slot in my crosscut table was so large.
I'll take a look tomorrow.
If it is this same set screw, what can I do to keep this from happening again?
Re: Powermatic 66
Re: Powermatic 66
Rod Peterson�Ormond Beach, FL
A common cure for that is to drive a second set screw down on top of the first. Sort of a jam screw in concept. You don't want a huge amount of torque on it—you don't want to strip the threads.
Rod
Re: Powermatic 66
Re: Powermatic 66
You could also use Loctite on that set screw.
Have you checked to see if the shaft is scarred and preventing the arbor nut from tightening? Without a blade on the saw, try to see if the nut will bring the washer closed against the collar on the shaft. You should be able to do that with your fingers. I don't have a PM 66 but my saw has Acme Threads (I think, they are the heavy squarish threads.) Mine got a slight burr on them somewhere along the way and I took a very small file and smoothed them. If you had a matching die you could run it over the shaft, but I assume the chance you have one is zero. Gently turn the shaft through your fingers and see if it is smooth. Carefully, a burr might cut you.
I have no Idea why it came loose in the beginning.
Is there a chance the pulley has come loose from the shaft and you just think its the blade?
Re: Powermatic 66
Re: Powermatic 66
Doug Reynolds
Taking the table saw arbor apart I discovered the arbor sheave was loose on the arbor shaft. I called Powermatic Technical Support and the tech said he did not know why the blade retaining nut would have come loose. Since I have the arbor apart I am going to replace the two bearings, clean things up and do a realignment.
Thanks for all your help and suggestions.
