OT computer problem
OT computer problem
OT computer problem
Doug Ridley
Bell south had an outage yesterday and when it was over I could only use my computer by disconnecting the router that goes to my wifes computer and hooking up directly from my computer to my modem. My computer works fine. But if I try to go thru the router to my wifes pc I can't use either one. It appears to me that the router is bad but all 4 lights are on. Any ideas?
Re: OT computer problem
Jim DeLaney, Austintown, Ohio
Might just need a 'total' reboot.
Try this:
1. Turn the computer off, and unplug the power to the modem and the router.
2. Wait a minute or so.
3. Plug in the modem, and wait for the 'ready' light. (may take a minute or two)
4. Plug in the modem, and wait for it to light up.
5. Boot up the computer.
6. Hope it works... ;-)
This is the procedure recommended by my cable provider. Works for me...
Jim D.
Doug Ridley
Thanks, Jim. Didn't work. Maybe the router is bad but what are the odds of it going bad at the instant of the Att. outage? Besides, all 4 lights are on.
Dave Paine
A power blip can be very bad for electronic components due to causing electrical spikes.
The reboot suggestion is the first to try. Since this has not worked, it is possible the router is now only useful for converting electricity into heat.
I would try connecting your PC to the router, and trying to access the router's Admin page. May need to look in the manual. My router defaulted to 192.168.0.1
If you are not able to connect to the Admin page, then the router is not managing IP address's and so will be useless.
If you are lucky the power blip has just re-set the unit to factory defaults and you may just need to re-apply whatever settings you had.
Good luck.
FYI, this is why I connect my PC's to a UPS.
Two weeks ago we had a power blip and the small PC connected to the TV for streaming internet radio was hit. It "only" corrupted files on the hard drive, this required a clean re-install of Windows 7. I have now purchased another UPS for this machine.
Bill Howatt
Router lights "on" are more of an indication that the network circuitry in the PC is turned on and the cable is plugged in. It doesn't guarantee connectivity.
Have you tried using different ports. It is possible for a single port to go bad.
Isolate the router to your PC only and do as suggested previously, try to get to the router's admin page. If you can, then check the settings. If they appear to be seriously out of whack, then reset the router to factory defaults and restart the setup.
If you can't do this to check the settings, try to reset the router to the factory defaults. On Linksys/Cisco this is usually a small hole that you insert a paper-clip or similar in and push. You will then have setup the router again especially for wireless connections.
Bill
David Hay Denver
The fact that you can connect directly tells me there's a problem with the router. A couple of things to try:
1. If you haven't already, unplug the router and let it sit for a while before plugging it back in...effectively rebooting the router.
2. The suggestion to get to the router's admin page is a good one. It may be that, as a result of the outage, the ISP reset all the DHCP servers, which would have invalidated your IP address. Your computer figured out that it needed to request a new IP address, but your router may not have realized there was a change. There may be a setting in the router menus that allow you to reset the network settings.
3. If #2 doesn't work, check the TCP/IP settings on your computer when connected directly to the modem and compare them to the settings the router has when it is connected to the modem.
Otherwise, you probably have a very pretty brick. Fortunately, routers are pretty cheap these days. You can pick up a wireless router (which also has hardwired connections) for around $40-$50.
David
Doug Ridley
Thanks all. I have tried all suggestions and nothing works.Can't get tech support without forking over $30.00. Bought a new router and will try to install it tomorrow. Can't handle any more today. Worn out with it.
Thanks,Doug
