200+ woodworking book reviews
Anyone familiar with the innards of a PC 333 ROS? *LINK*
Paul Cates - Henderson, KY
Replaced the belt after the original one broke, but what is missing (besides the belt) in the pic? The sander works with no belt, but the disk spins very fast when the sander's is not sanding wood. With the belt, the disk will not spin at all. I have looked at online diagrams and pictures, but I can't tell that I'm short any parts. I could take it to a service center, but I was hoping to avoid that. The link is an exploded drawing of the sander.
PC 333 exploded view
Re: Anyone familiar with the innards of a PC 333 ROS? *LINK*
del schisler
i bet their is a clutch inside Under where The belt goes It goes around the end pully which hold the center from turning unless it is in the sanding mode Take it to the repair center Your best bet good luck
Paul, I have two of them. One I bought because the first one crapped out and I needed it to finish a project while I got parts of the first one. I have worked on them over and over. Replaced the belt several times and there was something to do with the bearing. Wore out a bearing and tried to buy one locally and it was mismanufactured or mislabeled and broke the piece that held it. Got new factory parts and put it back together. Both are going strong right now. The point to all this is, I did it, you can too. Repairs are not a particularly strong suit for me. Look at it closely and make sure you have the belt in the correct place. Sorry I can't remember more details for you, but it seemed to be fairly straight forward.
buy a new one and keep the old one for parts.
Terry Alexander
They are so inexpensive now that I would just keep the one you have for parts and buy a new one. What's your time (and trouble) worth.
My $.02 worth.
Terry Alexander in West Texas
Thanks guys. I was hoping to avoid the purchase of a new sander, but may have to go that route if I can't find a fix.
Update, duh
The sander is fixed. All it needed was a belt, but I should have attached the pad and tried the sander before I assumed it wouldn't work right....all I did before was attach the belt and switch the sander on.
The belt is supposed to slip on the pulley, but I initially thought otherwise. It seems the vibration combined with the random orbit is what allows the slippage.
Re: Update, duh
I'm not sure it's really a belt in the traditional sense. Seems to me its a limiter (???) and actually slows the motion down. I think I recall mine going nuts when it coughed up the belt.
Congrats on getting it going.
Re: Update, duh
You're right, limiter is a better term. Thinking of it as a belt is what got me off track.
Rick Christopherson
The O-Ring you replaced is the pad brake for the PC sanders. It serves a purpose only when the sander is not on the workpiece, and is actually detrimental to the finish when the sander is actually sanding. The problem with the PC design is that their version of a pad brake was too effective, and nearly eliminates the "random" from "random orbit sander". This resulted in more visible scratches in the finish.
Someone was asking me about my review of sanders just a couple of days ago, so I scanned the old article into Acrobat. The graph below shows how dramatic the IMPROVEMENT in finish quality was when the pad brakes were removed from these sanders. The PC 332 (same as 333) had the greatest improvement in finish when the brake was removed, at 80% improvement.
If you can't live without the bad brake, I would do something to reduce its effectiveness. If it was my sander, I would leave it off. It is effective only when you have the sander up in the air.....so don't hold it up in the air.
Very good info, thanks.
