How in the world do you get sleeves off or on
Steve in Phoenix
Spindles! Grizzly G1071. The spindle has sat without a sleeve on it for a couple of days. Now I can only slide one on 3/4 of the way. Now I cannot get it off either...
Steve in Phoenix
Re: How in the world do you get sleeves off or on
Grant in Iowa
Assuming it is removable, lay the drum on its side and roll it like making a snake with clay. You can add more pressure by adding a board on top of the drum (like a teeter totter) and placing one hand on each end and going back and forth while applying downward force. Works for me with my spindle sander.
FWIW,
Thank You!!!
Steve in Phoenix
That worked perfectly. I used a 3' 2x4, starting at the bottom. and rolling to the top. The sleeve slipped right on. It's alot more pliable than I thought it would be...
You are the man,
Steve
