Somewhat OT recording to DVD's
Phil Joines Krum,Texas
I have about 100 VCR tapes on woodworking and turning (see it's related) that I want to record on DVDs. I bought a Dazzle video capture device that is working pretty good so far. The problem is the software says the run time for the disks is limited to 103 minutes and a lot of the tapes are 125 minutes or longer. Are there other types of disk or some way to compress the data without loosing too much quality? The software is Pinnacle Studio 12.
Re: Somewhat OT recording to DVD's
Tom
You can buy dual-layer disks. They're more expensive, maybe somewhere around $1 apiece. Make sure your burner can burn dual-layer (it'll probably say on the front). Really old ones won't. You can, most likely, also have your software save it to a file first and then recompress. I don't use Pinnacle products, so I don't know what format you're working with and what the software will let you do.
Bill Howatt
Are you sure there is no place in the software where you can set the quality or resolution to a lower value. It is possible to get several hours on a DVD at lower settings albeit with a reduction in quality. 103 minutes is a very high resolution/quality setting.
Bill
Lee Gordon
Lee Gordon
I have Pinnacle 10.7 and in the "Make Movie" tab there's a drop-down menu for "Disc Quality / Disc Usage" that lets you choose among "Automatic Quality," "Best Quality," "Most Video On Disc," or "Custom." I'm pretty sure all but "Best Quality" should let you fit at least 103 minutes onto a single DVD. I have a bunch of Wood Works episodes that, after editing out the breaks, run around 20 minutes each and I put four of them on each disc. I also record three New Yankee Workshop episodes (23 minutes each) per disc.
I can't imagine that Pinnacle 12 would have eliminated this ability, although it is not totally out of the question.
