OT - rebuilding a Kohler engine
Terry Alexander
I have a 7 year old Craftsman mower with a 16hp Kohler engine. Now, before some of you start spelling Craftsman with a "P" in it, this mower has served us well.....and we DID abuse it (in the country).
NEWay, can anybody recommend a (hopefully) step-by-step book on how to rebuild the engine? I am "pretty good" around mechanicals (obviously more comfortable (and skilled) with woodworking). Also, any "you need to know this" points would be appreciated.
Thanking you in advance.
Terry Alexander in West Texas
Re: OT - rebuilding a Kohler engine
Jorge Casta�eda
Terry,
I have a 1982 Troy Built tiller with a Kohler 7hp cast iron engine, we had to rebuild it last year after much use and abuse, as I did till for our self and others for many years. The mechanical part was straight forward, finding the right piston and sleeve was not, it helps to know exactly your model and serial No. We could not get original parts, but the local auto parts store, located after market parts. Now is a powerful machine once again.
If you have an exploded view with parts numbers, you are lucky and should not be much trouble to locate parts, besides yours is more recent.
Ray - Middletown, IN
You can probably get an exploded view from Kohler if you need it. There are several small engine parts places online, Jack's, Mowpart, smallenginewarehouse just to name a few. The model and serial number will be critical to ordering the correct parts and there will be a plate on the engine telling you that. Pretty straight forward from there.
Ray
Galen Vetterick
Kohler web site you can download some service manuals and others you can buy. They give info on wear tolerances before replacement, special tools you may need and bolt torques. Some photos of parts assemblies but pictures are a little rough. You need engine model and serial numbers. Check your local library as ours has some service and repair books of small engines.
