Repairing Formica, Actually related this time.
A year or two ago when Lowes put the Biesemeyer fences on closeout I got one and put it on my TS. I order for it to work I had to do something about the extension tables. (The Best fence slides on the table at the far end.) Mine were cast aluminum (?) grids. So, I epoxied thin plywood into the spaces between the ribs, ran them through the Performax to level everything and then covered them with Formica. As I recall, I used spirit based contact cement. (All of this was to explain why Formica glued to aluminum was related to wood working.)
Everything has been fine until yesterday. I noticed the corners for the Formica have come loose and popped up may a 1/32". Just enough for the fence to bump it when it slides by. I was really pleased with the Formica right up to that moment.
Now the question is How do I re-adhere the Formica and make it permanent? I would prefer not to remove it and start over.
Re: Repairing Formica, Actually related this time.
Bill Tindall
Solvent based adhesive can be "reactivated" by adding solvent, or more adhesive. Aluminum can be difficult to bond. I would be concerned why the bond failed.
Bill, My shop is unheated. Actually, no heat or AC. When I am in there I turn a portable electric heater or a window AC. I suspect among other things Temperature swings over time have had an impact on this. I had not thought about aluminum being difficult. Thanks. I think when I ran it through the Performax I roughed the surface and cleaned it.
Temp will have no real effect on your metal or mica, especially since the cement is far more flexible than either of the materials joined. Your edges will release because there is not enough glue there for a proper bond. I always tell people to put extra glue around the edges of mica work.
You problem now will be dust that has gotten under the mica. Squirt some lacquer thinner into the gap, wait a minute, repeat and squeeze the section moving from inside towards the edge. This will tend to push out at least some on the contaminants that you can wipe off. Open the joint and let it dry for a hour or so. Lastly work new solvent cement into the join and prop open again for a hour to allow the cement to reach its full tack. Lastly press together.
I've installed miles of formica..
Terry Alexander
...technically it's "laminated plastic" as "Formica" is a name brand. But that's a different subject.
I really have installed miles of formica. Had a job in college, installed formica, carpet, vinyl flooring, and tile all day and went to college at night.
IMO, once the edges (or edge) come loose, it is almost impossible to get it back down. You will end up with more than 1/32" gap in glue alone. Also, as a previous poster said, even the smallest amount of dirt or dust will degrade the glue joint.
You can try to repair, but if it was me, I'd bite the bullet and do it right.
My $.02 worth.
Terry Alexander in West Texas
